1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Cost effective solution for monitoring a large number of temperatures
To: Josh Stein <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 20 Jan 2006 10:31:17 +0100
Here with BESSY we ar going to install an version of our ADA-Card that offers in the VME-Bus version 32 temperature channels for PT100 sensors. This Card is delivered by EuKontrol and is about 2500 EUR, that means 78 EUR/channel. We use here the 3HE-Version with 16 channels per card and controlled via our embedded controler and the CAN-Bus. There is device support for EPICS available. A good feature is that this card uses the same long time stable integrating AD converter as all our ADA-Cards and so it is best suited in noisy environment with long cables to the sensor. I want to mention it because we had some trouble with that before.
Regards
Bernhard Kuner
RE: Cost effective solution for monitoring a large number of temperatures Darrell Nineham
Driver for Hytec 8601 IP Motor Controller? Doug Murray
Cost effective solution for monitoring a large number of temperatures Josh Stein
Prev: Re: Timestamp record? UPTIME Ralph Lange
Next: RE: Cost effective solution for monitoring a large number of temperatures Darrell Nineham
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Cost effective solution for monitoring a large number of temperatures D. Peter Siddons
