On Jan 15, 2006, at 23:08 , Liu Shu wrote:
Hi Kay:
Thank you for you help.
Here I directly use the vxStatsApp for my IOC.Whan I run st.cmd
in ioc
console.I got the results below:
</home/liushu/epicsinstall/vxStats/vxStats/iocBoot/ioctest/st.cmd
# Example vxWorks startup file
#Following must be added for many board support packages
#cd <full path to target bin directory>
cd "/home/liushu/epicsinstall/vxStats/vxStats/iocBoot/ioctest"
value = 0 = 0x0
< cdCommands
startup = "/home/liushu/epicsinstall/vxStats/vxStats/iocBoot/ioctest"
startup = 0x1ffe8c0: value = 15535248 = 0xed0c90 =
prsrv_cast_client + 0x58
appbin = "/home/liushu/epicsinstall/vxStats/vxStats/bin/ppc604_long"
appbin = 0x1ffe848: value = 15535176 = 0xed0c48 = prsrv_cast_client
+ 0x10
#nfsMount "ics-srv02", "/ade/epics/iocTop/R3.13.7/front_end/3-1","/
bootBase"
#nfsMount "ics-srv02", "/sns/ADE/home/carl/vxStats/3-1", "/startup"
#nfsMount "ics-srv02", "/sns/ADE/home/carl/vxStats/3-1", "/stats"
#< ../nfsCommands
#ld < /bootBase/bin/ppc603/epicsArchLd.o
cd appbin
value = 0 = 0x0
ld < iocCore
value = 33549096 = 0x1ffeb28 = pCaBucket + 0x38
ld < seq
value = 10908600 = 0xa673b8
ld < vxStatsLib
value = 10656984 = 0xa29cd8 = ca_server_port + 0x78
#epicsArchLd("/bootBase/bin/%s/iocCore");
#epicsArchLd("/bootBase/bin/%s/bootBaseLib");
#epicsArchLd("/bootBase/bin/%s/seq")
#dbLoadDatabase("/bootBase/dbd/bootBase.dbd");
iocLogDisable =1
iocLogDisable = 0x871634: value = 1 = 0x1
#epicsArchLd("/startup/bin/%s/vxStatsLib");
cd startup
value = 0 = 0x0
dbLoadDatabase("../../src/base.dbd")
liushu:bash: line 1:
/home/liushu/epicsinstall/vxStats/vxStats/iocBoot/ioctest/?value =
filename="../db-LexRoutines.c" line1 number=236
S_errno = 0x_EBUSY dbRead offffffffpening file .. = /../src/base.dbd
pnivxi_func + 0xfe00124f
dbLoadDatabase("../../dbd/vxStats.dbd")
Error " record type not found" Last token ")"
input line: device(stringin,INST_IO,devStringinStats,"VX stats")
in: file ../../dbd/vxStats.dbd line 1757
in: file ../../dbd/vxStats.dbd line 3514
db_parse returned -1
value = -1 = 0xffffffff = pnivxi_func + 0xfe00124f
dbLoadTemplate("../../src/Db/ioc.substitutions")
dbLoadTemplate:
error opening sub file ../../src/Db/ioc.substitutions
iocInit
Star### ting iocInit
@(#)EPICS IOC CORE built on Jan 18 2005
### @(#)Version R3.13.8 $2003/02/04 19:59:44$
Failed to set time from Unix server
value = 0 = 0x0
I edited directly the st.cmd of vxStats.The result shows me there's
something wrong while loading dbd files.
Right. Looks like the stringin record, which could be found
in EPICS base, is not.
When I create a new application as what you said.There's no
testInclude.dbd
file but exampleInclude.dbd.
That's the one.
Then I create the testInclude.dbd and include
vxStats.dbd.And need I copy those dbd files into my new
applicaions,such as
the vxStats.dbd?
No copy should be necessary.
By adding something like
VX_STATS = /path/to/vxStats
to your apps' configure/RELEASE file
(config/RELEASE for R3.13),
the necessary files are found without
having to copy them into your app.
You said "edit my_great_apps/testApp/src/Makefile* to include the
library".Do you mean edit the src/Makefile.Vx and add:
LIBOBJS += $(VX_STATS)/bin/ppc604_long/vxStatsLib
And I should also copy those vxstats db files to my own
applications,right?
Because VX_STATS is defined in RELEASE,
you can use that variable in
LIBOBJS += $(VX_STATS)/bin/ppc604_lo....
without need to copy.
-Kay
- vxStats liushu
- Re: vxStats Kay-Uwe Kasemir
Re: vxstats for Epics 3.13.8 Benjamin Franksen
Beam Extracted from SNS Ring Gurd, David P.
<2006>
RE: vxStats Gurd, Pamela A.
<2006>
