Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017
Subject: RE: About: timeout handler of epicsTimer
To: "Andrew Johnson" <anj@aps.anl.gov>, "Jun-ichi Odagiri" <jun-ichi.odagiri@kek.jp>
Cc: "EPICS tech-talk" <tech-talk@aps.anl.gov>
Date: Thu, 12 Jan 2006 19:09:29 -0600
Andrew wrote:
> Yes it is allowed, but you should be aware of the
> implications of this:
> If the semaphore blocks, then none of the other epicsTimers
> that use the  same epicsTimerQueue will be executed until the
semaphore is released
> and the callback/notify routine returns.  It is not advisable for a
> timer on the system shared timer queue to block for any signficant
> period of time in its callback/notify routine.  The use of
> printf() and similar functions is fine though because it should not
block for any
> significant period of time.
I don't think I agree with the statement that printf() should not block
for any significant period of time.
On vxWorks printf() does block, and since the I/O is often going to a
9600 baud console port, it can be very slow.  In fact if the user types
^S to pause the output the task will hang until ^Q is typed.
Here's a little test program that measures how many clock ticks are
required to use printf() to print 100 output lines:
corvette> more printf_test.c
#include <tickLib.h>
#include <stdio.h>
void printf_test()
    int i;
    long int start;
    start = tickGet();
    for (i=0; i<100; i++) printf("This is line %d\n", i);
    printf("Total ticks=%ld\n", tickGet()-start);
Here's the output under normal circumstances:
ioc13lab> printf_test
This is line 0
This is line 1
This is line 2
This is line 3
This is line 96
This is line 97
This is line 98
This is line 99
Total ticks=72
value = 15 = 0xf
So it took 72 clock ticks, or over 1 second.
If I press ^S for a while during the output, the task hangs while that
is going on, and I got 546 clock ticks while I waited about 10 seconds.
So I don't think it's a good idea to call printf in a callback routine.
epicsPrintf() is much better, since it just puts output in a buffer, and
does not wait for the actual I/O to complete.
RE: About: timeout handler of epicsTimer Jun-ichi Odagiri
Prev: RE: About: timeout handler of epicsTimer Jun-ichi Odagiri
Next: Re: vxStats Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017
Next: RE: About: timeout handler of epicsTimer Jun-ichi Odagiri
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
