g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013
Subject: About: timeout handler of epicsTimer
To: "'EPICS tech-talk'" <tech-talk@aps.anl.gov>
Date: Thu, 12 Jan 2006 10:14:22 +0900
Dear All,
I'm wondering if the following statement about epicsTimer is correct or not.
#Start of the statement
Any handler of epicsTimer runs, when the timer expired, not in an interrupt
context but in a normal task's (thread's) context.
This goes for the case where the iocCore program is running on vxWorks or
RTEMS, or whatever OS supported in Base.
#End of the statement
What I'd like to know is, in other words, if a handler of epicsTimer is
allowed to take semaphores in the handler or not.
I guess the statement is TRUE because I have found an example of a handler
to call printf, in "IOC Application Developer's Guide (Chp.19, Section
10.4)".
Still, I feel I need to confirm it more...
Thanks a lot in advance.
Jun-ichi Odagiri
High Energy Accelerator Research Organization, KEK
Oho 1-1, Tsukuba, Ibaraki, Japan
Re: About: timeout handler of epicsTimer Andrew Johnson
Prev: RE: pv connect/disconnect callbacks Jeff Hill
Next: Re: orderly shutdown Ernest L. Williams Jr.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013
Next: Re: About: timeout handler of epicsTimer Andrew Johnson
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
