Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017
Subject: RE: How to check an external PV from IOC shell
To: Ned Arnold <nda@aps.anl.gov>, "Zhou, Jingchen" <jingchen@slac.stanford.edu>
Cc: tech-talk@aps.anl.gov
Date: Tue, 10 Jan 2006 17:49:21 -0500
You can at least get information about external ca connections using the
"dbcar" routine.
Ernest
-----Original Message-----
Sent: Tue 1/10/2006 5:22 PM
To: Zhou, Jingchen
Subject: Re: How to check an external PV  from IOC shell
Zhou, Jingchen wrote:
> Is there any simple way to check status of an external PV from IOC shell?
> For example, I am at a IOC shell
> epics>
> Is there any IOC shell command (or some way) that allow me do things like "dbpr external_PV" or "caget external_PV"?
> Thanks,
> Jingchen
I am not aware of any IOC based tools that support this *directly*. It
would be a useful utility if you chose to develop it.
However, there is always the hack!
If you have a spare record in your IOC (e.g. a soft AI record) you could ...
dbpf "softAI.INP", "externalPV"
dptr "softAI"
The STAT field will reflect if the external PV was found, the .VAL will
reflect its value.
	Ned
How to check an external PV from IOC shell Zhou, Jingchen
Re: How to check an external PV from IOC shell Ned Arnold
Prev: Re: How to check an external PV from IOC shell Ned Arnold
Next: RE: Timestamp record? UPTIME Emmanuel Mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017
Next: RE: Timestamp record? UPTIME Steven Banks
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
