Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017
Subject: Re: How to check an external PV from IOC shell
To: "Zhou, Jingchen" <jingchen@slac.stanford.edu>
Cc: tech-talk@aps.anl.gov
Date: Tue, 10 Jan 2006 16:22:10 -0600
Zhou, Jingchen wrote:
Is there any simple way to check status of an external PV from IOC shell?
For example, I am at a IOC shell
epics>
Is there any IOC shell command (or some way) that allow me do things like "dbpr external_PV" or "caget external_PV"?
Jingchen
I am not aware of any IOC based tools that support this *directly*. It would be a useful utility if you chose to develop it.
However, there is always the hack!
If you have a spare record in your IOC (e.g. a soft AI record) you could ...
dbpf "softAI.INP", "externalPV"
dptr "softAI"
The STAT field will reflect if the external PV was found, the .VAL will reflect its value.
Ned
RE: How to check an external PV from IOC shell Williams Jr, Ernest L.
How to check an external PV from IOC shell Zhou, Jingchen
Prev: How to check an external PV from IOC shell Zhou, Jingchen
Next: RE: How to check an external PV from IOC shell Williams Jr, Ernest L.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
