g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013
Subject: EPICS Base R3.14.8.2 is now available
To: EPICS tech-talk <tech-talk@aps.anl.gov>
Date: Fri, 06 Jan 2006 16:53:48 -0600
The R3.14.8.2 patch release fixes the epicsStrtod() issue that crept into R3.14.8.1, and also removes some of the compiler warnings that are generated when using the latest version of the Microsoft compilers. If your site has already incorporated the patch that Eric Norum posted to fix the epicsStrtod() problem there should be no reason to upgrade to R3.14.8.2, although the final fix is very slightly different to Eric's proposal.
See the R3.14.8 page for details:
	http://www.aps.anl.gov/epics/base/R3-14/8.php
- Andrew
* * Matt Santos / / For a Brighter America * *
Prev: Re: A couple of drvAsyn/devGpib questions Marty Kraimer
Next: Re: Timestamp record? Jeff Gebhardt
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
