Noboru Yamamoto wrote:
Eric Norum wrote:
It appears that this mixup occurred when epicsStdlib.c was added.
What about making the following change?
Index: epicsStdlib.c
RCS file:
/net/phoebus/epicsmgr/cvsroot/epics/base/src/libCom/misc/epicsStdlib.c,v
retrieving revision 1.1.2.1
diff -u -r1.1.2.1 epicsStdlib.c
--- epicsStdlib.c 12 Dec 2005 19:54:46 -0000 1.1.2.1
+++ epicsStdlib.c 26 Dec 2005 18:22:40 -0000
@@ -43,6 +43,9 @@
return 1;
+#ifdef epicsStrtod
+# undef epicsStrtod
+#endif
epicsShareFunc double epicsStrtod(
const char *str, char **endp)
I'm quite surprised that this problem didn't show up during
pre-release testing. I suspect that it will cause the same infinite
recursion on all POSIX targets.
In the distribution, there are several place where I can find osdStrtod.h:
[noboru-g4:libCom/osi/os] noboru% find ./ -name osdStrtod.h -print
.//RTEMS/osdStrtod.h
.//WIN32/osdStrtod.h
.//cygwin32/osdStrtod.h
.//hpux/osdStrtod.h
.//posix/osdStrtod.h
.//vxWorks/osdStrtod.h
On Linux, the inline-function version of strtod is used and this endless
recursion is avoided. If you use "-fno-inline" option for buiding EPICS,
caget on Linux will go into the endless recursion.
Noboru
These files other than posix/osdStrtod.h include lines:
* epicsStrtod() for systems with broken strtod() routine
epicsShareFunc double epicsShareAPI epicsStrtod(const char *str, char
**endp);
However, the origiral distribution does not have this type of
osdStrtod.h in the osi/os/Darwin directory and cases the infinite
recursion.
Noboru
On Dec 26, 2005, at 12:14 AM, Noboru Yamamoto wrote:
I encountered a problem to run EPICS CA clients build with
EPICSR3.14.8.1 under MacOSX 10.3/10.4.
In the osdStrtod.h under base-3.14.8.1/src/libCom/osi/posix, macro
epicsStrtod is defined as:
#define epicsStrtod strtod
On the otherhand , the file epicsStdlib.c in
base-3.14.8.1/src/libCom/ includes the definition of epicsStrtod.
Because <epicsStrtod.h> is included before the definition of
epicsStrtod function, this definition
acually defines strtod as a external funtion.
The epicsStrtod calls a strtod function inside it. It ends up the
infinite calling sequence. For example, a simple "caget fred" command
will never end in this environment.
I'm not quite sure if this problem is related to my development
environment( MacOSX 10.3/10.4 with gcc3, distributed by Apple . I
don't use any fink command.)
1) Is there any other who encounter the same or similar problem with
EPICS3.14.8.1?
2) there may be severay ways to avoid this phenomena, but which one
do you like to take. For example, just remove the sentence
or define a new macro like
#define HAS_WORKING_STRTOD_IN_SYSTEM 0
and skip the definition of epicsStrtod.
Or better otherway?
Thank you very much for your attension.
Noboru Yamamoto
EPICS group/JPARC control group
KEK, JAPAN
Eric Norum <[email protected] <mailto:[email protected]>>
Advanced Photon Source
Argonne National Laboratory
(630) 252-4793
- building EPICSR3.14.8.1 on MacOSX 10.3/10.4 Noboru Yamamoto
- Re: building EPICSR3.14.8.1 on MacOSX 10.3/10.4 Eric Norum
- Re: building EPICSR3.14.8.1 on MacOSX 10.3/10.4 Noboru Yamamoto
Design Question Mathias Steiner
<2005>
<2005>
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
