1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: building EPICSR3.14.8.1 on MacOSX 10.3/10.4
To: Eric Norum <[email protected]>
Cc: Marty Kraimer <[email protected]>, Janet Anderson <[email protected]>, "'[email protected]'" <[email protected]>
Date: Tue, 27 Dec 2005 08:11:18 +0900
Eric Norum wrote:
It appears that this mixup occurred when epicsStdlib.c was added. What about making the following change?
Index: epicsStdlib.c
RCS file: /net/phoebus/epicsmgr/cvsroot/epics/base/src/libCom/misc/epicsStdlib.c,v
retrieving revision 1.1.2.1
diff -u -r1.1.2.1 epicsStdlib.c
--- epicsStdlib.c 12 Dec 2005 19:54:46 -0000 1.1.2.1
+++ epicsStdlib.c 26 Dec 2005 18:22:40 -0000
@@ -43,6 +43,9 @@
return 1;
+#ifdef epicsStrtod
+# undef epicsStrtod
+#endif
epicsShareFunc double epicsStrtod(
const char *str, char **endp)
I'm quite surprised that this problem didn't show up during pre-release testing. I suspect that it will cause the same infinite recursion on all POSIX targets.
In the distribution, there are several place where I can find osdStrtod.h:
[noboru-g4:libCom/osi/os] noboru% find ./ -name osdStrtod.h -print
.//RTEMS/osdStrtod.h
.//WIN32/osdStrtod.h
.//cygwin32/osdStrtod.h
.//hpux/osdStrtod.h
.//posix/osdStrtod.h
.//vxWorks/osdStrtod.h
These files other than posix/osdStrtod.h include lines:
* epicsStrtod() for systems with broken strtod() routine
epicsShareFunc double epicsShareAPI epicsStrtod(const char *str, char **endp);
However, the origiral distribution does not have this type of osdStrtod.h in the osi/os/Darwin directory and cases the infinite recursion.
Noboru
On Dec 26, 2005, at 12:14 AM, Noboru Yamamoto wrote:
I encountered a problem to run EPICS CA clients build with EPICSR3.14.8.1 under MacOSX 10.3/10.4.
In the osdStrtod.h under base-3.14.8.1/src/libCom/osi/posix, macro epicsStrtod is defined as:
#define epicsStrtod strtod
On the otherhand , the file epicsStdlib.c in base-3.14.8.1/src/libCom/ includes the definition of epicsStrtod. Because <epicsStrtod.h> is included before the definition of epicsStrtod function, this definition
acually defines strtod as a external funtion.
The epicsStrtod calls a strtod function inside it. It ends up the
infinite calling sequence. For example, a simple "caget fred" command will never end in this environment.
I'm not quite sure if this problem is related to my development environment( MacOSX 10.3/10.4 with gcc3, distributed by Apple . I don't use any fink command.)
1) Is there any other who encounter the same or similar problem with EPICS3.14.8.1?
2) there may be severay ways to avoid this phenomena, but which one do you like to take. For example, just remove the sentence
or define a new macro like
#define HAS_WORKING_STRTOD_IN_SYSTEM 0
and skip the definition of epicsStrtod.
Or better otherway?
Thank you very much for your attension.
Noboru Yamamoto
EPICS group/JPARC control group
KEK, JAPAN
Eric Norum <[email protected] <mailto:[email protected]>>
Advanced Photon Source
Argonne National Laboratory
(630) 252-4793
Re: building EPICSR3.14.8.1 on MacOSX 10.3/10.4 Noboru Yamamoto
Re: building EPICSR3.14.8.1 on MacOSX 10.3/10.4 Eric Norum
Prev: Re: building EPICSR3.14.8.1 on MacOSX 10.3/10.4 Eric Norum
Next: Re: building EPICSR3.14.8.1 on MacOSX 10.3/10.4 Noboru Yamamoto
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
