1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: building EPICSR3.14.8.1 on MacOSX 10.3/10.4
To: "'[email protected]'" <[email protected]>
Date: Mon, 26 Dec 2005 15:14:27 +0900
I encountered a problem to run EPICS CA clients build with EPICSR3.14.8.1 under MacOSX 10.3/10.4.
In the osdStrtod.h under base-3.14.8.1/src/libCom/osi/posix, macro epicsStrtod is defined as:
#define epicsStrtod strtod
On the otherhand , the file epicsStdlib.c in base-3.14.8.1/src/libCom/ includes the definition of epicsStrtod. Because <epicsStrtod.h> is included before the definition of epicsStrtod function, this definition
acually defines strtod as a external funtion.
The epicsStrtod calls a strtod function inside it. It ends up the
infinite calling sequence. For example, a simple "caget fred" command will never end in this environment.
I'm not quite sure if this problem is related to my development environment( MacOSX 10.3/10.4 with gcc3, distributed by Apple . I don't use any fink command.)
1) Is there any other who encounter the same or similar problem with EPICS3.14.8.1?
2) there may be severay ways to avoid this phenomena, but which one do you like to take. For example, just remove the sentence
or define a new macro like
#define HAS_WORKING_STRTOD_IN_SYSTEM 0
and skip the definition of epicsStrtod.
Or better otherway?
Thank you very much for your attension.
Noboru Yamamoto
EPICS group/JPARC control group
KEK, JAPAN
Re: building EPICSR3.14.8.1 on MacOSX 10.3/10.4 Eric Norum
Prev: Re: about using NI-1014 with VME/Linux Eric Norum
Next: Re: building EPICSR3.14.8.1 on MacOSX 10.3/10.4 Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: asynDriver R4-4 Marty Kraimer
