1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: record field definition and float
To: [email protected]
Date: Wed, 21 Dec 2005 15:30:57 -0500
	I tested small client program with different types. I was lazy
to do special server (IOC) and tried to use different fields. Everything
was Ok - double, enum, int, string, char.
	But float ... :(
For example ao record has (according Record manual) DRVH as float. But
my client returned double.
	I looked into code. Code has DRVH as double. It means record
manual has mistakes.
Thanks, Andrei.
Re: record field definition and float Andrew Johnson
Prev: Re: epics extension Emmanuel Mayssat
Next: Re: record field definition and float Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: epics extension Benjamin Franksen
