1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: epics extension
Cc: Ralph Lange <[email protected]>, Christophe Moins <[email protected]>, EPICS Tech Talk <[email protected]>
Date: Wed, 21 Dec 2005 09:34:50 -0800
The build system is quite frustrating for new comers.
The makefile includes files which themselves include other files.
So quite tricky to understand the details, specifically when it doesn't
build.
If you don't want to know about the build system, then we have something
in common ;-)
My advice to you is that instead of modifying your Makefile, you may
want to change your environment and use the gmake -e option.
That way you will be able
1/ to keep the original files in the base
      ( very useful if you want to upgrade epics very easily or build
several base in different directories, etc.)
2/ You can keep track of your change
3/ you can automate the build process in scripts
To find the variable you need to set it is a little more tricky
but you can use gmake -p
Enjoy!
Emmanuel Mayssat
Cell: 650/793-0626
Lyncean Technologies, Inc.
"See the invisible"
Re: epics extension Benjamin Franksen
epics extension Christophe Moins
Re: epics extension Ralph Lange
Re: epics extension Andrew Johnson
Prev: Re: epics extension Andrew Johnson
Next: record field definition and float Liyu, Andrei
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: epics extension Benjamin Franksen
