1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Problem with XML RPC
To: "Waggoner, Bill" <[email protected]>
Cc: tech talk <[email protected]>, "Gorbunov, Yury" <[email protected]>
Date: Tue, 20 Dec 2005 08:28:54 -0500
Hi:
There should be a file similar to
 /tmp/archserver.log
that logs the request which the network data server saw.
If you exercise that same request with ArchiveDataClient.pl,
you might see a better error message.
Right now I don't know what the problem is.
The archive data files could be damaged,
but that shouldn't be the case with the
demo data.
Are the data files accessible?
Maybe you just made the index file accessible,
but not the data files?
-Kay
On Dec 19, 2005, at 23:21 , Waggoner, Bill wrote:
Hi Kay,
Thank you for your suggestion - it worked.
We have one more question. right now by doing:
[sysuser@sc XMLRPCServer]$ ./ArchiveDataClient.pl -u http:// sc.starp.bnl.gov/archive/cgi/ArchiveDataServer.cgi -k 1 -l
Channels:
Channel BoolPV, 03/05/2004 18:53:56.767577600 - 03/05/2004 18:58:51.901960000 Channel DTL_HPRF:Tnk1:T, 03/01/2004 17:28:00.035262000 - 03/29/2004 13:01:00.230310000 Channel DTL_HPRF:Tnk2:T, 03/01/2004 17:28:00.035262000 - 03/29/2004 13:00:00.031041000 Channel DTL_HPRF:Tnk3:T, 03/01/2004 17:27:59.985282000 - 03/29/2004 13:01:00.280299000 ...
we do see all channels inside index file but once we try to run it with ArchiveViewer and plot it gives the error message :
java.lang.Exception: Couldn't execute the archiver.values request java.io.IOException: org.xml.sax.SAXParseException: expected Element
and in console: Fatal error parsing XML: org.xml.sax.SAXParseException: expected Element
Any idea?
Bill && Yura
Thanks
-----Original Message----- From: Kay-Uwe Kasemir [mailto:[email protected]] Sent: Sunday, December 18, 2005 7:53 PM To: tech talk Subject: Re: Problem with XML RPC
Hi:
Well, I assume that
'/home/sysuser/epics/extensions/src/ChannelArchiver/DemoData/index'
is actually an existing path & filename that you configured.
The error message indicates that your web server &
ArchiveDataServer are also OK, otherwise
you'd never get as far as that error message.
The web server runs your copy of the network data server
as "nobody" or a similar low-privilege user.
So the next thing to check would be that
/home/sysuser/epics/extensions/src/ChannelArchiver/DemoData/*
and all the directories in the path to ... DemoData
have 'r-x' access for "nobody" or whoever's configured
in your web server to run CGI code.
-Kay
On Dec 18, 2005, at 19:04 , Waggoner, Bill wrote:
Hi All,
We installed epics 3.14.8 with ChannelArchiver (compilled without
any problems).
The box is Scientific Linux SL release 3.0.5 (SL) with Apache/
2.0.46.  We have a small problem with ArchiveDataServer -
it's up and running  but if we try to check the index file in the
DemoData we run into the error message :
[sysuser@sc ChannelArchiver]$ ArchiveDataClient.pl -u http:// sc.starp.bnl.gov/archive/cgi/ArchiveDataServer.cgi -k 1 -m Ex Channels: Fault returned from XML RPC Server, fault code -601: Cannot open index '/home/sysuser/epics/extensions/src/ChannelArchiver/DemoData/ index'
Any suggestions?
Thanks, Bill Waggoner && Yura Gorbunov
No virus found in this incoming message.
Checked by AVG Free Edition.
Version: 7.1.371 / Virus Database: 267.13.13/198 - Release Date: 12/12/2005
Internal Virus Database is out-of-date.
RE: Problem with XML RPC Waggoner, Bill
Prev: RE: Problem with XML RPC Waggoner, Bill
Next: New release of VisualDCT! Shepherd, EL (Emma)
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Fwd: Problem with XML RPC Kay-Uwe Kasemir
