1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Ethernet/IP: writing zero to soft tags --- More Info
To: tech talk <[email protected]>
Date: Sat, 17 Dec 2005 20:50:59 -0500
On Dec 17, 2005, at 17:00 , John Dobbins wrote:
Some additional info regarding this problem of writing to soft tags.
First, I should have made clear this has to do with bo records.
Second, if I compare a hardware tag and a soft tag I see that when they are read the hardware tag, e.g. Local:9:O.Data[0], is treated as a bit in an integer whereas the soft tag reads back as a boolean, value =255 or 0.
For EIP_verbosity=10 the following excerpt illustrates this, there is a record that references Local:9:O.Data[0] which results in the tag Local:9:O.Data being read back as a group of bits and a record that references the soft tag remote_reset_a and reads back the boolean value 255 ("on").
It seems to me that when I subsequently try to write a zero to the soft tag remote_reset_a, the value 255 is treated by the Ethernet/ IP driver as a collection of bits, the lowest bit is set to zero to generate the value 254. This is then written and interpreted by the controller as "on". (?)
Yes, the network protocol used by the Ethernet/IP driver doesn't really know 'boolean' nor 'bit'. The driver reads/writes integer data, and depending on the record type it assumes that you really meant to deal with only a bit in the integer, except when you use the 'B' flag etc.
So in order to look at this, I
really need the exact record definition.
Preferably: The definition of the one and only record
in your database that reproduces the problem.
Also the RSLogix declaration for your "soft tag".
-Kay
Ethernet/IP: writing zero to soft tags --- More Info John Dobbins
Prev: Ethernet/IP: writing zero to soft tags --- More Info John Dobbins
Next: Problem with XML RPC Waggoner, Bill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
