We have the following problem using Ethernet/IP device support (and EPICS R3.14.7) with an Allen-Bradley ControlLogix PLC. We can write to hardware output tags (things like Local:9:O.Data[1]) just fine, however when we try to write to a soft tag, i.e. a controller tag or a program tag, we find we can write a "one" but not a "zero". There was a related thread in 2004, beginning with http://www.aps.anl.gov/epics/tech-talk/2004/msg00636.php but it wasn't clear to me whether this issue was resolved. If I set EIP_verbosity = 10 and look at the output (see below) the only difference between writing a "one" and writing a "zero" is the data sent. In the case of writing a "one" the data sent is "ff", when writing a "zero" the data sent is "fe". Is it possible "fe" counts as zero for a hardware output but not for a "soft" tag? Any advice or suggestions on how to further debug are welcome. Thanks John Dobbins Lab for Elementary Particle Physics Cornell University Write Zero Request: epics> ------------------- New Request ------------ EncapsulationHeader: UINT command = 0x6F (SendRRData) UINT length = 64 UDINT session = 0x12023400 UDINT status = 0x00000000 (OK) USINT context[8]= 'Funstuff' UDINT options = 0x00000000 Send RR Data UDINT interface handle 0 UINT timeout 0 UINT count (addr., data) 2 UINT address_type 0x00 (UCMM) UINT address_length 0 UINT data_type 0xB2 (Unconnected Message) UINT data_length 48 MR Request USINT service = 0x52 (CM_Unconnected_Send) USINT path size = 2 words Path: Class 0x6 (ConnectionManager), instance 1 USINT tick time = 10 USINT ticks = 240 UINT message size = 33 ... (embedded message of 33 bytes) USINT path_size = 1 words USINT reserved = 0x0 Path: Port 1, link 0 Embedded Message: MR Request USINT service = 0xA (S_CIP_MultiRequest) USINT path size = 2 words Path: Class 0x2 (MessageRouter), instance 1 UINT count 1 Request #0 (remote_reset_a): MR Request USINT service = 0x4D (CIP_WriteData) USINT path size = 8 words Path: Tag 'remote_reset_a' UINT type = 0xC1 UINT elements = 1 Data: 00000000 FE - . Data sent (88 bytes): 00000000 6F 00 40 00 00 34 02 12 00 00 00 00 46 75 6E 73 - [email protected] 00000010 74 75 66 66 00 00 00 00 00 00 00 00 00 00 02 00 - tuff............ 00000020 00 00 00 00 B2 00 30 00 52 02 20 06 24 01 0A F0 - ......0.R. .$... 00000030 21 00 0A 02 20 02 24 01 01 00 04 00 4D 08 91 0E - !... .$.....M... 00000040 72 65 6D 6F 74 65 5F 72 65 73 65 74 5F 61 C1 00 - remote_reset_a.. 00000050 01 00 FE 00 01 00 01 00 - ........ Write One Request: epics> ------------------- New Request ------------ EncapsulationHeader: UINT command = 0x6F (SendRRData) UINT length = 64 UDINT session = 0x12023400 UDINT status = 0x00000000 (OK) USINT context[8]= 'Funstuff' UDINT options = 0x00000000 Send RR Data UDINT interface handle 0 UINT timeout 0 UINT count (addr., data) 2 UINT address_type 0x00 (UCMM) UINT address_length 0 UINT data_type 0xB2 (Unconnected Message) UINT data_length 48 MR Request USINT service = 0x52 (CM_Unconnected_Send) USINT path size = 2 words Path: Class 0x6 (ConnectionManager), instance 1 USINT tick time = 10 USINT ticks = 240 UINT message size = 33 ... (embedded message of 33 bytes) USINT path_size = 1 words USINT reserved = 0x0 Path: Port 1, link 0 Embedded Message: MR Request USINT service = 0xA (S_CIP_MultiRequest) USINT path size = 2 words Path: Class 0x2 (MessageRouter), instance 1 UINT count 1 Request #0 (remote_reset_a): MR Request USINT service = 0x4D (CIP_WriteData) USINT path size = 8 words Path: Tag 'remote_reset_a' UINT type = 0xC1 UINT elements = 1 Data: 00000000 FF - . Data sent (88 bytes): 00000000 6F 00 40 00 00 34 02 12 00 00 00 00 46 75 6E 73 - [email protected] 00000010 74 75 66 66 00 00 00 00 00 00 00 00 00 00 02 00 - tuff............ 00000020 00 00 00 00 B2 00 30 00 52 02 20 06 24 01 0A F0 - ......0.R. .$... 00000030 21 00 0A 02 20 02 24 01 01 00 04 00 4D 08 91 0E - !... .$.....M... 00000040 72 65 6D 6F 74 65 5F 72 65 73 65 74 5F 61 C1 00 - remote_reset_a.. 00000050 01 00 FF 00 01 00 01 00 - ........
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
