I think the thing to do would be to separate out the soft support for the subarray record from the rest of the record; it really is too closely coupled now. Then whatever buffering it uses to deal with the outside could be in the device support code which would be tailored as needed. Should I take this as a hint that my hack is likely to come unstuck? In truth I'm tending back to using separate length and index controls managing standard waveform records, but it isn't that code's turn yet... I took care to avoid tampering with epics itself, so the only change I've made is that my subArray init_record reassigns MALM to a much larger value. I haven't worked that code very hard yet, as other stuff has intervened, but at first glance it seemed to work ok.
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
