1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: EDM wants to build on vxWorks-68040 target. Why?
To: Mark Wagner <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Wed, 23 Nov 2005 09:38:09 -0500
On Tue, 2005-11-22 at 17:58 -0800, Mark Wagner wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> On Thu, Oct 27, 2005 at 11:16:45AM -1000, Maren Purves wrote:
> > looks like you have a Makefile.Vx in your soruce directory.
> > If so, either delete it or rename it to something else.
> There was no Makefile.Vx in my source directory.
> I followed the maze of Makefile includes to the culprit. In
> ${MY_EPICS_BASE}/configure/CONFIG_COMMON
The extensions tree also has a configure directory.
Most of the extensions that we use if not all are host-side only.
For example, CA client apps, EPICS database tools, or some other misc
EPICS utility are host-based.
So, what we have always done when building with R3.14.7; set
the variable "CROSS_COMPILER_TARGET_ARCHS" to NULL
Modify:
$(EPICS_EXTENSIONS)/configure/CONFIG
The following is what we have:
================ CONFIG ============================
[williams@ics-accl-srv1 configure]$ more CONFIG
# $Id: CONFIG,v 1.1 2004/06/02 06:04:06 williams Exp $
include $(TOP)/configure/CONFIG_EXTENSIONS
# Add any changes to make rules here
CROSS_COMPILER_TARGET_ARCHS =
The above works great and I hope it is the recommended way.
If you don't want all extensions to inherit the
CROSS_COMPILER_TARGET_ARCHS setting then you can override things in the
local Makefiles of desired extension package.  For example, SDDS may
some target-side tools as well as host-side?
HTH,
Ernest L. Williams Jr.
SNS Control Systems Group
ORNL
> there is
> BUILD_ARCHS = $(EPICS_HOST_ARCH) $(CROSS1) $(CROSS2)
> Changing that to
> fixed the problem. (I then changed it back after compiling edm.)
> I'm an EPICS newbie so I'm looking for a bit of enlightenment with these
> questions:
> Why would edm, or any other extension, use BUILD_ARCHS, when they will
> run on the EPICS_HOST_ARCH only?
> How can I tell edm, without touching stuff in ${MY_EPICS_BASE}, that it
> shouldn't build for the target(s), only the host? I tried mucking with
> stuff in ${EPICS_EXTENSIONS}/configure and ${EPICS_EXTENSIONS}/src/edm
> to no avail.
> Is there an extension that is a shining example of the proper use of
> the EPICS 3.14 build system?
> > Mark Wagner wrote:
> > >I'm trying to build EDM on a linux-x86 host, which seems to go OK.
> > >However, it seems as though it is trying to be built for the vxWorks-68040
> > >target too, which causes all sorts of problems. How can I make it not
> > >do that?
> > >epics 3.14.7
> > >edm 1-10-1zf
> > >extensionsConfigure_20040406
> > >extensionsConfig_20040406
> Mark Wagner [email protected] 206-598-0302
> Unix System Administrator, Radiation Oncology
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.4.2 (GNU/Linux)
> iD8DBQFDg8y0vOs2g/c480IRAlJDAJ9fcylurjZuLp9ofGeDsGO4BL/wtQCdE5CX
> ueo46SB9CVWzWItMF2fjsU0=
> =g2ZX
> -----END PGP SIGNATURE-----
EDM wants to build on vxWorks-68040 target. Why? Mark Wagner
Re: EDM wants to build on vxWorks-68040 target. Why? Mark Wagner
Prev: RE: EPICS base compiling using Visual C++ 2005 Express guobao shen
Next: RE: EPICS base compiling using Visual C++ 2005 Express Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: EDM wants to build on vxWorks-68040 target. Why? Mark Wagner
Next: RE: EDM wants to build on vxWorks-68040 target. Why? Singleton, SJ (Steve)
