1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: EDM wants to build on vxWorks-68040 target. Why?
To: [email protected]
Date: Tue, 22 Nov 2005 17:58:12 -0800
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
On Thu, Oct 27, 2005 at 11:16:45AM -1000, Maren Purves wrote:
> looks like you have a Makefile.Vx in your soruce directory.
> If so, either delete it or rename it to something else.
There was no Makefile.Vx in my source directory.
I followed the maze of Makefile includes to the culprit. In
${MY_EPICS_BASE}/configure/CONFIG_COMMON
there is
BUILD_ARCHS = $(EPICS_HOST_ARCH) $(CROSS1) $(CROSS2)
Changing that to
fixed the problem. (I then changed it back after compiling edm.)
I'm an EPICS newbie so I'm looking for a bit of enlightenment with these
questions:
Why would edm, or any other extension, use BUILD_ARCHS, when they will
run on the EPICS_HOST_ARCH only?
How can I tell edm, without touching stuff in ${MY_EPICS_BASE}, that it
shouldn't build for the target(s), only the host? I tried mucking with
stuff in ${EPICS_EXTENSIONS}/configure and ${EPICS_EXTENSIONS}/src/edm
to no avail.
Is there an extension that is a shining example of the proper use of
the EPICS 3.14 build system?
> Mark Wagner wrote:
> >I'm trying to build EDM on a linux-x86 host, which seems to go OK.
> >However, it seems as though it is trying to be built for the vxWorks-68040
> >target too, which causes all sorts of problems. How can I make it not
> >do that?
> >epics 3.14.7
> >edm 1-10-1zf
> >extensionsConfigure_20040406
> >extensionsConfig_20040406
Mark Wagner [email protected] 206-598-0302
Unix System Administrator, Radiation Oncology
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.2 (GNU/Linux)
iD8DBQFDg8y0vOs2g/c480IRAlJDAJ9fcylurjZuLp9ofGeDsGO4BL/wtQCdE5CX
ueo46SB9CVWzWItMF2fjsU0=
=g2ZX
-----END PGP SIGNATURE-----
Re: EDM wants to build on vxWorks-68040 target. Why? Ernest L. Williams Jr.
EDM wants to build on vxWorks-68040 target. Why? Mark Wagner
Prev: RE: Getting CA data with VC Jeff Hill
Next: RE: EDM wants to build on vxWorks-68040 target. Why? Singleton, SJ (Steve)
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: EDM wants to build on vxWorks-68040 target. Why? Mark Wagner
Next: Re: EDM wants to build on vxWorks-68040 target. Why? Ernest L. Williams Jr.
