I looked into this "w+bTD" verses "W+B".
The purpose of this code is to open an identical type of temporary file on
all OS. This particular problem is, of course, in Microsoft specific code
working with previous versions, but not with Visual C++ 2005.
The very latest documentation at MS with a 2005 time stamp on it lists "T"
and "D" as valid Microsoft specific options to _fdopen. This therefore
smells like a bug at MS. Nevertheless, the proposed change appears to work -
not creating any permanent files on the disk. This is probably because
roughly equivalent options are specified to the preceding open().
We have committed the suggested change - ETA R3.14.8.
Jeff
> -----Original Message-----
> From: Vladimir Sirotenko [mailto:[email protected]]
> Sent: Tuesday, November 22, 2005 9:34 AM
> To: guobao shen; [email protected]
> Subject: Re: EPICS base compiling using Visual C++ 2005 Express
> Try to do the following, it worked for us:
> Antelope failed to run correctly because it could not create a temporary
> file.
> Modify src\libCom\osi\WIN32\epicsTempFile.cpp and remove the TD from the
> fdopen specification.
> pNewFile = _fdopen ( fd, "w+b" ); instead of pNewFile = _fdopen (
> fd, "w+bTD" );
> Vladimir
> From: "guobao shen" <[email protected]>
> To: <[email protected]>
> Sent: Tuesday, November 22, 2005 8:19 AM
> Subject: EPICS base compiling using Visual C++ 2005 Express
> > Dear all,
> > I am trying to compile the EPICS 3.14.7 on Windows XP SP2 using
> > MS Visual C++ 2005 express version for evaluation. I met some problem
> > when the antelope.exe was executed. It reported the following erros and
> > exited.
> > "antelope.exe has encountered a problem and needs to close. We are
> > sorry
> > for the inconvenience."
> > "Please tell Microsoft about this problem".
> > Is there any one succeeded in compiling EPICS base using that compiler?
> > Thanks,
> > Guobao Shen
> > J-PARC Control Group
- RE: EPICS base compiling using Visual C++ 2005 Express guobao shen
- Re: EPICS base compiling using Visual C++ 2005 Express Vladimir Sirotenko
EDM on Windows + Hummingbird? Michael E Urashka
<2005>
<2005>
