Xu, hi
I looked couple minutes I
didn’t understand anything L Sorry.
If you are newcomer in
Epics, please, look on simple example in Jeff Hill CA’s book http://www.aps.anl.gov/epics/base/R3-14/7-docs/CAref.html
(search “main (“ ).
I can send couple
simplest examples too.
Good luck, Andrei.
Hello,
I compiled the following code but there were several errors and I don't know
how to solve those problems.
Here is the code:
#include "stdafx.h"
#include <cadef.h>
#define MAXLEN 20
#define POLL 1.0e-9
#define SHRT_DLY 0.1
#define LNG_DLY 0.25
struct Channel
dbr_string_t name;
chid chan;
struct Channel *next;
struct Channel *prev;
}*pFirst=NULL,*pLast;
void connect_handler1(struct connection_handler_args);
void connect_handler2(struct connection_handler_args);
void an_event_handler(struct event_handler_args);
struct Channel *search(char *Name);
int main()
int status,i,j,k;
dbr_float_t *pValue;
dbr_string_t Value;
dbr_string_t Name[MAXLEN];
struct Channel *pCurrent;
unsigned long Nelem;
/*initialize Channel Access task*/
SEVCHK(ca_task_initialize(),"Unable to
initialize");
/*Get channel names and establish connection for
each.*/
/*Allocat memory for first node, and then for each
additional node*/
/*after connection is established. Loop until user
enters "quit".*/
for(printf("Enter a channel name.\n"),
pCurrent=(struct Channel
*)calloc(1,sizeof(struct
Channel));
gets(Name)!=NULL&&strcmp(Name,"quit")!
=0;
name or \"quit\" to stop.\n"))
SEVCHK(status,NULL);
ca_pend_event(LNG_DLY);
if(ca_state(pCurrent->chan)!=cs_conn)
printf("couldn't establish connection to %
s;ignoring\n",pCurrent->name);
else
pCurrent=(struct Channel *)calloc(1,sizeof(struct
Channel));
//Install a dirrerent connection handler on each
channel.
if(pFirst!=NULL)
for(pCurrent=pFirst;pCurrent!=NULL;pCurrent=pCurrent->next)
status=ca_change_connection_event(pCurrent-
>chan,connect_handler2);
SEVCHK
(status,"ca_change_connection_event:couldn't change handler");
ca_flush_io();
//Loop until "quit" is entered. Get Channel
name.
//If found, prompt for values; else skip rest of loop.
//Call ca_put_callback().
for(i=0,printf("%s\n%s\n","Enter the
PV's name","Enter \"quit\" to
stop");
gets(pCurrent->name)!=NULL&&strcmp(pCurrent->name,"quit")!
=0;
printf("%s\n","Enter PV name or \"quit\" to
stop"))
ca_pend_event(POLL);
pCurrent=search(Name);
if(pCurrent==NULL)
printf("Cannot find channel name in list.
Disconnected?\n");
continue;
Nelem=ca_element_count(pCurrent->chan);
if(Nelem==1)
printf("Enter value.\n");
if(gets(Value)!=NULL)
status=ca_put_callback
(DBR_STRING,//EXTERNAL TYPE
pCurrent->chan,//chid
Value,//string of value
an_event_handler,//callback
pCurrent/*user supplied address*/);
else if(Nelem>1)
printf("Enter up to %u values or q to
quit.\n",Nelem);
pValue=(float *)calloc(Nelem,sizeof(*pValue));
for(k=0;(j=scanf("%f",pValue+k))==1&&j!
=EOF&&k<Nelem;k++)
j=getchar();
status=ca_array_put_callback(DBR_FLOAT,//external
type
Nelem,//no. of elements to be
sent
pValue,//array of vlaues
address*/);
ca_pend_event(SHRT_DLY);
return 0;
void connect_handler1(struct connection_handler_args connect_args)
//set point to user-supplied address
pCurrent->chan=ca_puser(connect_args.chid);
//if connect up, initialize list or add node
if(connect_args.op==CA_OP_CONN_UP)
if(pFirst==NULL)
pFirst=pCurrent;
pFirst->prev=NULL;
pLast=pCurrent;
pLast->next=pCurrent;
pCurrent->prev=pLast;
pCurrent->next=NULL;
pLast=pCurrent;
printf("%s is
connected.\n",pCurrent->name);
//if connection down print message .
//this block is unlikely to ever be used.
else
printf("%s is not
return;
void connect_handler2(struct connection_handler_args connect_args)
struct Channel *pPrevious,*pNext;
//if connection down, free memory of user supplied
address,
//and delete nodes from list.
if(connect_args.op==CA_OP_CONN_DOWN)
pCurrent=ca_puser(connect_args.chid);
pPrevious=pCurrent->prev;
pNext=pCurrent->next;
pPrevious->next=pNext;
pNext->prev=pPrevious;
free(pCurrent);
else if(pCurrent==pLast&&pCurrent!=pFirst)
pLast=pCurrent->prev;
pLast->next=NULL;
free(pCurrent);
else
if(pCurrent==pFirst&&pCurrent!=pLast)
pFirst=pCurrent->next;
pFirst->prev=NULL;
free(pCurrent);
else
if(pCurrent==pFirst&&pCurrent==pLast)
pFirst=NULL;
pLast=NULL;
free(pCurrent);
printf("%s:channel
disconnected.\n",ca_name
(connect_args.chid));
//if re-connected, re-allocate memory
else if(connect_args.op==CA_OP_CONN_UP)
Channel));
connect_args.chid->puser=pCurrent;
strcpy(pCurrent->name,ca_name(connect_args.chid));
if(pFirst==NULL)
pFirst=pCurrent;
pFirst->prev=NULL;
pLast=pCurrent;
else
pLast=pCurrent;
printf("%s:channel re-connected.\n",pCurrent->name);
return;
void an_event_handler(struct event_handler_args handler_args)
if(handler_args.status!=ECA_NORMAL)
printf("channel %s:put
operation not successful.\n",ca_name
(handler_args.chid));
SEVCHK(handler_args.status,NULL);
else
operation completed.\n");
return;
using undefined type“oldChannelNotify”
can't convert“void *”to“Channel *”
can't convert“void *” to“chid”
I wonder how to solve
it.
Thanks!
