John Dobbins wrote:
Dear All,
I am trying to boot EPICS on RTEMS-uC5282. I get the following output.
How do I proceed from here? Thanks,
John Dobbins
B$ go
go! 0x10000000
***** Initializing network *****
Startup after External reset.
fs1: Ethernet address: f8:91:8a:c4:36:25
***** Initializing NFS *****
This is RTEMS-RPCIOD Release rtems-addon-packages-4-6-99-2
(rpcio.c,v 1.1 2005/09/02 15:40:51 joel Exp)
Till Straumann, Stanford/SLAC/SSRL 2002
See LICENSE file for licensing info
This is RTEMS-NFS Release SSRL_RTEMS_20041202
(nfs.c,v 1.33 2004/09/22 22:10:41 till Exp)
Trying to mount 172.17.1.101:/mnt/disk1 on /mnt
assertion "RTEMS_SUCCESSFUL == rtems_semaphore_obtain( (llock),
RTEMS_WAIT, RTE3
Assertion failed - would be interesting to see the line number + having
more information.
Usually, this happens:
a) not enough resources configured (in this case, however, creation
already should
have failed and you wouldn't have gotten that far.
b) called from wrong environment (from ISR or not from a task). From
where and
how do you call nfsInit() ?
c) side-effect of general corruption.
You can change the 'MU_LOCK()' macro in rpciod.c from
assert( condition )
to retrieve the return value of rtems_semaphore_obtain() and
print it on failure (use 'printk()').
HTH
-- T.
- Problem booting EPICS on RTEMS-uC5282 John Dobbins
Writing to PVs Xu HuiJuan
<2005>
<2005>
