1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: record/device support general style question
To: <[email protected]>
Date: Thu, 17 Nov 2005 15:49:53 -0000
Jens,
What I have done in the past is to support I/O interrupt scanning for
these sort of variables. Then whenever a write is initiated on a
variable, any other variables which are read in the same operation but
which are set to be I/O interrupt scanned are automatically updated.
What the driver has to recognize is that a set of variables all have the
same command string, and parse out different bits of the response string
to each one.
Cheers,
Nick Rees
Principal Software Engineer           Phone: +44 (0)1235-778430
Diamond Light Source                  Fax:   +44 (0)1235-446713
> -----Original Message-----
> From: Jens Rekow [mailto:[email protected]]
> Sent: 17 November 2005 15:38
> To: [email protected]
> Subject: record/device support general style question
> Hi All,
> it is rather an architectural/style question that I ran into
> working on
> the device support for a message based serial/ethernet device
> (yes, it is
> the LoCuM4).
> Imagine there is a command that retrieves various status values binary
> encoded in a string (bytes, shifted to printable
> characters...). I would
> like to serve several PV's out of that. (It wouldn't make
> sense to put so
> much information in just one record, mbbi, whatsoever)!
> As always there are different ways to deal with that:
> Worst case that I can think of is to have AsynDriver device
> support for
> each record, so EACH time ONE of them is processed there would be I/O
> transaction at the interface for retrieving the whole status
> string and
> the tiny bit (literally!) of interest will be extracted.
> My way so far is another: There is one AsynDriver-powered record
> (stringin) which retrieves and holds the status string. That
> value is read
> by a longin record via dbGetField() in a standard device
> support, which
> extracts the information and distributes to all the other
> relevant records
> via dbPutField(). Thus these other records don't need any
> device/record
> support implementation themselves but are set remotely.
> Unfortunately this
> complicates handling the alarm/invalid states of these records.
> So the question is:
> Would it be better to have already my AsynDriver-powered record, which
> reads the status bytes, distributing the values to the
> different records
> via dbPutField()?
> Alternatively I like the idea of only one device support
> implementation
> for several records which is flexible using the INP field as a
> parameter...
> Any suggestions?
> What could be more 'stylish'?
> Thanks in advance,
> Jens
Prev: record/device support general style question Jens Rekow
Next: RE: record/device support general style question Liyu, Andrei
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: record/device support general style question Marty Kraimer
