1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: RTEMS-uC5282 build problem
To: "Allison, Stephanie" <[email protected]>
Cc: EPICS Tech-Talk <[email protected]>
Date: Wed, 16 Nov 2005 15:54:44 -0500
Stephanie,
You are right. It turns out that CONFIG.Common.RTEMS-uC5282 doesn't come with the R3.14.7 distribution. I got it from cvs and build is now proceeding. Thanks.
John Dobbins
Allison, Stephanie wrote:
Hi John,
make[3]: *** No rule to make target `../O.Common/osiFileName.h', needed by `inc'. Stop.
I wonder if OS_CLASS is not being set to RTEMS for your build. Either your base/configure/os/CONFIG.Common.RTEMS isn't setting it (OS_CLASS=RTEMS has been removed?) or your CONFIG.Common.RTEMS-uC5282 file is not including CONFIG.Common.RTEMS or something of this nature.
Stephanie Allison
RE: RTEMS-uC5282 build problem Allison, Stephanie
Prev: Re: Real time video with epics Kay-Uwe Kasemir
Next: Next RTEMS-uC5282 build problem John Dobbins
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: RTEMS-uC5282 build problem Allison, Stephanie
