1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Ethernet camera
To: <[email protected]>
Cc: "Tech-talk" <[email protected]>
Date: Wed, 16 Nov 2005 13:44:26 +0100
Hi Matjaz,
At the SLS we interfaced CCD cameras with Firewire bus to EPICS (3.14.7 on Linux RH7.3), you can find all the info and the source code under:
http://epics.web.psi.ch/software/firewire/
We think Firewire is a good choice as it supports isochronous data - delivering data at a guaranteed rate. This makes it ideal for devices that need to transfer high priority data in real-time, such as video devices. It is also fast (400Mbit/sec) (53 frames/sec @ 1Byte and 1024*768 pixels and 80% usable bandwidth), actually, this is more than what the EPICS video server PC can process. The EPICS video server grabs the frames from the camera, process them, and then allow any CA enabled client application to access the processed data, this way we save our network bandwidth.
Cheers,
Ahed
# Ahed Aladwan
# SLS Controls / Paul Scherrer Institute
# WSLA/208, 5232 Villigen PSI Switzerland
# Tel:+41 56 310 4594
# Fax:+41 56 310 4413
# www.psi.ch
# http://people.web.psi.ch/adwan/
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Matjaz Kobal
Sent: Tuesday, November 15, 2005 12:34 PM
To: [email protected]
Subject: Ethernet camera
Hello,
We would like to integrate an ethernet camera into EPICS. Does anyone
know of already existing solutions.
Thank you.
_____________________   _   _   _   _   ____________________
                     |_| |_| |_| |_| |_|
 Matjaz Kobal, Ph.D.                                Cosylab
 Senior Software Developer           http://www.cosylab.com
 Email: [email protected]           Teslova ulica 30
 Phone: +386 (1) 4776-767                 SI-1000 Ljubljana
 Cell:  +386 (40) 996-466                          Slovenia
__   _   _   _   _   __________________   _   _   _   _   __
  |_| |_| |_| |_| |_|                  |_| |_| |_| |_| |_| ìì
Real time video with epics Emmanuel Mayssat
Prev: RE: availiabity EPICS serial RTU modbus driver Bruins, Stefan
Next: RTEMS-uC5282 build problem John Dobbins
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Ethernet camera Matjaz Kobal
Next: Real time video with epics Emmanuel Mayssat
