1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Building 3.14.7 on win32-x86 with Visual C++ 6.0
To: <[email protected]>, <[email protected]>
Date: Mon, 14 Nov 2005 09:32:39 -0700
Title: Message
Hello Jinhyuk Choi ,
Of course the root cause of inconvience is that we are using different versions
of visual visual C++. For example, I am using visual studio.NET 2003 which has
better compliance with ANSI C++ standards compared to visual C++ 6.0.
One of the changes proposed would actually prevent the code from compiling with a
standards compliant compiler. For example with recent versions of GNU g++ the
following result occurs.
    for (unsigned i=0; i<10; i++);
    for (i=0; i<10; i++);
/cygdrive/d/users/hill/epicsDvl/epics/base$ g++ tmp.cpp
tmp.cpp: In function `int main()':
tmp.cpp:5: error: name lookup of `i' changed for new ISO `for' scoping
tmp.cpp:4: error:   using obsolete binding at `i'
Nevertheless, I have committed changes to CVS for R3.14.8
(availalable soon for testing via a nightly snbapshot) that should
hopefully allow visual studio 6.0 to be used also.
> 1. No /GL, /w44355 options for cl
> 2. No /LTCG option for link
These command line switches, available only with the more recent compiler,
do generate warnings if used with the older compiler.
One possible way to avoid the warnings would be to create a set of
config files for host architecture win32-x86-MSVS6.0
> I wish this list can help to someone.
No doubt that they will.
Thanks very much for your assistance.
Jeff
 -----Original Message-----
Sent: Friday, November 11, 2005 2:15 AM
To: [email protected]
Subject: Building 3.14.7 on win32-x86 with Visual C++ 6.0
Hi all,
I'm a beginner in EPICS.
With some experience with Visual C++6,
I've built 3.14.7 on win32-x86 correcting some errors.
The errors fixed are as follows.
1. base/src/libCom/osi/epicsThread.cpp
std::unexpected () -> unexpected ()
visual C get unexpected() out of std namespace.
2. base/src/ca/udpiiu.cpp
line 244: remove unsigned in "unsigned i"
duplicated definition
3. base/src/ca/tcpiiu.cpp
line 1982: remove return in "return nettiu::uninstallChannel...()
void should not return something
4. base/src/gdd/dbMapper.cc
line 1108 & 1134: remove int in "int i"
I've finished building with some warnings:
Please forgive me if someone has already addressed the above points.
For the warnings, I should study further and any help will be appreciated.
Still it should be checked if it works fine.
Jinhyuk Choi
Pohang Accelerator Laboratory
Building 3.14.7 on win32-x86 with Visual C++ 6.0 최진혁
Prev: RE: OPC WITH EPICS Liyu, Andrei
Next: Re: OPC WITH EPICS / OPC-Server for EPICS Matthias Clausen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Building 3.14.7 on win32-x86 with Visual C++ 6.0 최진혁
Next: synApps Workshop Rees, NP (Nick)
