1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: OPC WITH EPICS
To: Xu HuiJuan <[email protected]>, [email protected]
Date: Mon, 14 Nov 2005 08:50:52 -0500
	I suppose you couldn't do easy :) because Epics is server and
OPC is server too. But you can do enough easy double levels servers
structure (one server on top, another on bottom). So
- Epics (top) to OPC (Epics (as client) connects to OPC server)
or
- OPC (top) to Epics (OPC connects to CA).
	If I am not mistaken first variant has done in Germany. They use
standard device (PLC?) with OPC server. Look on Epics workshop of this
March/April.
	About OPC server. It will be better if you will use toolkit.
Look on http://www.opcfoundation.org/ . They had some free products.
Good luck, Andrei.
P.s. Of course, you can do what you wrote. But one of the servers (OPC
or Epics) must be slave again in one task space. In the bottom it means
you couldn't use two main(){} functions in one program.
I also suppose if Epics will have another variant (as slave) it will add
openness to Epics community. That will give possibility to include Epics
into LabVIEW, MatLab or another commercial products.
-----Original Message-----
Sent: Monday, November 14, 2005 12:53 AM
To: [email protected]
Subject: OPC WITH EPICS
Hello,
Is there anybody develop an OPC Server on the EPICS?
I'm a beginner of studying OPC. I want to know the working principle of
the
OPC Server and how to achieve the data conversion.
Thanks!
Prev: OPC WITH EPICS Xu HuiJuan
Next: Re: OPC WITH EPICS Bernhard Kuner
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: OPC WITH EPICS / OPC-Server for EPICS Matthias Clausen
Next: RE: OPC WITH EPICS Liyu, Andrei
