1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Channel Archiver/ Extension Build Question
To: John Dobbins <[email protected]>
Cc: Kay-Uwe Kasemir <[email protected]>, [email protected]
Date: Thu, 10 Nov 2005 11:59:23 +0100
Hi John,
To me it does actually look like there's one "make" missing in the extensions/configure subdirectory.
Remember that running "make" inside the configure directory creates Makefile snippets that get included during all make runs under this TOP. These Makefile snippets contain (among other things) search path definitions for includes and libraries.
The pearl script that creates the library path definitions will only add directories that actually contain libraries - this is to avoid adding countless empty directories to the search paths.
If you created librecIoc.a in base after you ran make in extensions/configure, your Makefile snippets might not contain the correct library location within base. As a result, make will try to find librecIoc.a only locally, i.e. under this TOP directory. It's not there, and cannot be created locally, so make complains correctly about
*** No rule to make target `../../../../lib/linux-x86//librecIoc.a
General rule of thumb: If a make run yields errors that look like it's trying to find a library locally which should be found elsewhere ...
  • Make sure the path to the external module (in which the library is located) is set correctly in TOP/configure/RELEASE.
  • Make sure the library does exist in that module at the generic location (e.g. MODULE/lib/ARCHITECTURE)
  • Do a "make clean", then "make" (or shorter: "make clean all") inside TOP/configure.
If it still doesn't work, well ... shit happens.
Good luck!
Ralph
Kay-Uwe Kasemir wrote:
Hi:
Well, I cannot duplicate your exact setup right now,
Re: Channel Archiver/ Extension Build Question John Dobbins
Re: Channel Archiver/ Extension Build Question Kay-Uwe Kasemir
Prev: RE: help guobao shen
Next: Re: Channel Archiver/ Extension Build Question John Dobbins
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Channel Archiver/ Extension Build Question Kay-Uwe Kasemir
