1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Channel Archiver/ Extension Build Question
To: John Dobbins <[email protected]>
Cc: [email protected]
Date: Wed, 9 Nov 2005 23:04:20 -0500
Hi:
Well, I cannot duplicate your exact setup right now,
but for what it's worth, below is the result on a
Mac w/ R3.14.6.
Tomorrow I can check the output for some Redhat linux
and R3.14.7.
Anyway, the sequence performed by make that I get is this:
- compile several *.cpp files, FUX.cpp being the last one
- combine all the *.o into libTools.a
- build some test code, which indeed links recIoc,
  searching both the 'base' and 'extension' lib dirs,
  presumably locating recIoc in the 'base' lib dir.
The point is:
Your make's error message
"...librecIoc.a', needed by `libTools.a'"
doesn't make sense to me since libTools.a
doesn't include librecIoc.a
Well, these lines in Tools/Makefile could result in
trying to link librecIoc.a into libTools.a:
# In case of shared lib, link these:
Tools_LIBS += $(EPICS_BASE_IOC_LIBS)
... but ChannelArchiver/make.cfg should assert
that you're not trying to build shared libs:
# These are overrides for CONFIG_SITE.
SHARED_LIBRARIES = NO
Did you change that setting?
-Kay
My build log for .../Tools:
/usr/bin/c++ -c -DOSITHREAD_USE_DEFAULT_STACK -DUNIX - ansi -g -Wall -D ARCH_VERSION=2 -D ARCH_RELEASE=6 -D ARCH_PATCH=0 -D ARCH_VERSION_TXT=\"2.6.0\" -I/Users/kasemir/epics/ R3.14.6/base/include -I/Users/kasemir/epics/R3.14.6/base/include/os/ Darwin -I/usr/local/xerces-c-src2_4_0/include -fno-common -fPIC - I. -I.. -I../../../../include/os/Darwin -I../../../../ include ../FUX.cpp
/usr/bin/ar -rc libTools.a ArchiveException.o ArgParser.o ASCIIParser.o BenchTimer.o BinIO.o Bitset.o CGIDemangler.o epicsTimeHelper.o Filename.o GenericException.o IndexConfig.o Lockfile.o MemoryPool.o MsgLogger.o NetTools.o RegularExpression.o stdString.o FUX.o
/usr/bin/ranlib libTools.a
Installing library ../../../../lib/darwin-ppc/libTools.a
/usr/bin/ranlib ../../../../lib/darwin-ppc/libTools.a
/usr/bin/c++ -c -DOSITHREAD_USE_DEFAULT_STACK -DUNIX - ansi -g -Wall -D ARCH_VERSION=2 -D ARCH_RELEASE=6 -D ARCH_PATCH=0 -D ARCH_VERSION_TXT=\"2.6.0\" -I/Users/kasemir/epics/ R3.14.6/base/include -I/Users/kasemir/epics/R3.14.6/base/include/os/ Darwin -I/usr/local/xerces-c-src2_4_0/include -fno-common -I. - I.. -I../../../../include/os/Darwin -I../../../../include ../ ToolsTest.cpp
/usr/bin/c++ -o ToolsTest -L../../../../lib/darwin-ppc/ -L/Users/ kasemir/epics/R3.14.6/base/lib/darwin-ppc/ -L/usr/local/lib - lxerces-c ToolsTest.o -lTools -lrecIoc -lsoftDevIoc - liocsh -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom -lm
On Nov 9, 2005, at 20:03 , John Dobbins wrote:
Dear All,
I am trying to build Channel Archiver with EPICS R3.14.7 on linux-x86.
I start from a blank slate by installing/building base into the directory base-3.14.7
I then download extensionsConfigure_20040406.tar.gz and unzip it so I now have the following tree
base-3.14.7/
   Makefile
   bin/
extensions/
   Makefile
   configure/
I edit extensions/configure/RELEASE so that the value of EPICS_BASE is correct.
I create the directory extensions/src into which I unzip archiver.tgz (a 11/07/2005 snapshot of the Channel Archiver) so that now I have
extensions/
   Makefile
   configure/
   src/
      ChannelArchiver
         Makefile
         /Tools
I change directory to extensions/src/ChannelArchiver and type "make".
Make creates the directory Tools/O.linux-x86, and then begins compiling the source in the Tools directory. When it gets to FUX.cpp I get the output:
/usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS - D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux - D_REENTRANT -ansi -g -Wall -D ARCH_VERSION=2 -D ARCH_RELEASE=6 -D ARCH_PATCH=0 -D ARCH_VERSION_TXT=\"2.6.0\" -I/mnt/ disk1/tmp/jad/ca_test/base-3.14.7/include -I/mnt/disk1/tmp/jad/ ca_test/base-3.14.7/include/os/Linux -I/usr/local/xerces-c-src2_4_0/ include -g -fPIC -I. -I.. -I../../../../include/os/Linux - I../../../../include ../FUX.cpp
make[2]: *** No rule to make target `../../../../lib/linux-x86// librecIoc.a', needed by `libTools.a'. Stop.
make[2]: Leaving directory `/mnt/disk1/tmp/jad/ca_test/extensions/ src/ChannelArchiver/Tools/O.linux-x86'
make[1]: *** [install.linux-x86] Error 2
make[1]: Leaving directory `/mnt/disk1/tmp/jad/ca_test/extensions/ src/ChannelArchiver/Tools'
make: *** [Tools.install] Error 2
It is looking for librecIoc.a in the wrong place? (extensions/lib/ linux-x86 instead of base-3.14.7/lib/linux-x86)
Can someone please suggest how to fix this?
Regards and thanks,
John Dobbins
Lab for Elementary Particle Physics
Cornell University
Ithaca, NY
Re: Channel Archiver/ Extension Build Question Ralph Lange
Channel Archiver/ Extension Build Question John Dobbins
Prev: help Xu HuiJuan
Next: RE: help guobao shen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Channel Archiver/ Extension Build Question John Dobbins
Next: Re: Channel Archiver/ Extension Build Question Ralph Lange
