Malcom,
I use an indirect method to call st.cmd. I can't recall why I ended up
doing it that way. As Eric suggested I have specified the path for the
executable. Does the envPaths file look correct?
$ cat st.boot_iocs1
#!/bin/csh
cd /eprun/ioc157/iocBoot/ioclin7
screen -d -m -S ioc -h 1000 ./iocstart
$ cat iocstart
#!/bin/csh
../../bin/linux-x86/lin7 st.cmd
-ps
----- Original Message -----
To: "Walters, M (Malcolm)" <[email protected]>
Cc: <[email protected]>
Sent: Tuesday, November 08, 2005 12:23 PM
Subject: Re: Running softIoc's in the background
On Nov 8, 2005, at 11:12 AM, Walters, M (Malcolm) wrote:
I have been trying to run a Linux softIoc in the background by
using the
screen command. When I try to specify the startup script at the
same
time (i.e. "screen ./st.cmd"), the ioc starts but on any caget/
caput/...
command the screen terminates without any error message.
What happens if you specify the executable explicitly rather than
starting the executable from the script?
i.e.
screen /full/path/to/bin/linux-x86/iocExecutable st.cmd
If I start the screen and then run the startup script I don't have
any
problems. This problem occurs for every database we have tried. Has
anybody else had any similar problems or any ideas what might be
causing
this?
We are running R3.14.7.
Eric Norum <[email protected]>
Advanced Photon Source
Argonne National Laboratory
(630) 252-4793
- Re: Running softIoc's in the background Steven Hartman
- Running softIoc's in the background Walters, M (Malcolm)
- Re: Running softIoc's in the background Eric Norum
<2005>
<2005>
