1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Driver for Sorenson PS - DLM Series
To: Martin Pieck <[email protected]>
Cc: [email protected]
Date: Tue, 8 Nov 2005 08:36:52 -0600
On Nov 7, 2005, at 6:12 PM, Martin Pieck wrote:
Hello,
Has anybody developed a driver that communicates with Sorenson
DLM Series (M130 Ethernet Option) Power Supplies ???
According to the manual this should be possible via one of the
following methods:
- raw socket interface sending delimited strings (SCPI)
This is supported by the ASYN drvAsynIPPort driver.
- utilizing VXI-11 Discovery protocol
The ASYN drvVxi11 driver should be close to what's needed here. It would be great to hear what success you have with this since LXI (Lan eXtensions for Instrumentation) is built on this protocol.
-       web-server
-       RS232C
drvAsynSerial
In all the above cases you need "only" to write the ASYN devGpib command table entries. The same command table should work for all three communication mechanisms.
Eric Norum <[email protected]>
Advanced Photon Source
Argonne National Laboratory
(630) 252-4793
Driver for Sorenson PS - DLM Series Martin Pieck
Prev: linux-xscale port, SYSFS device support Peter Milne
Next: Running softIoc's in the background Walters, M (Malcolm)
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Driver for Sorenson PS - DLM Series Martin Pieck
Next: linux-xscale port, SYSFS device support Peter Milne
