I've recently ported BASE 3.14.7 to run on linux-xscale (so that our intelligent digitizers now have IOC functionality on board). The patch to build the IOC is available here: http://www.d-tacq.com/epics.shtml The port was very straightforward, thanks to the excellent EPICS build system. If anyone is planning to repeat this exercise, the only issue with xscale (and probably any little-endian ARM processor) on Linux is that the floating point library has another take on little-endianness compared to the norm - easily corrected as shown in the patch. A second point that may be of interest to list members is Device Support for Sysfs: It's increasingly common in modern Linux systems to use device files on Sysfs to enable simple user space access to kernel parameters. Or in our case, to nail up a Linux VFS with a file per channel. I couldn't find suitable Device Support for this functionality, so I wrote a simple but generic "dsSysfs" device support interface, using "ai" records and encoding the location and characteristics of the files in the INP field. So, for example, it's easy to create records for AI monitoring: field(INP, "@/dev/mean/01 rb4") # reads the rolling mean for channel 01 as a 4 byte integer ... field(INP, "@/dev/mean/96 rb4") # reads the rolling mean for channel 96 as a 4 byte integer Heartbeat (generic to any Linux system) : field(INP, "@/proc/uptime") # read the ascii data from this file or even System health monitor: field(INP, "@#!sysmon -T 1") # read the [ascii] result of spawned task sysmon (temperature monitor). The source code and doc is freely available at http://www.d-tacq.com/epics.shtml If there already is the means to do this in EPICS, do let me know, it will be useful to compare features. Thanks Peter. -- Peter Milne [email protected] D-TACQ Solutions Ltd www.d-tacq.com
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
