1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: RGA Device Driver
To: [email protected], [email protected]
Date: Mon, 7 Nov 2005 09:13:09 -0600 (CST)
At APS we have Spectra's RGA which is now owned by MKS system. We have been
using  two models of RGA units -RGA vacscan plus and the Spectra Satalite RGA.
I think the Satalite RGA is now the MKS RGA unit.
The Vacscan plus was originally developed under HIDEOS however it was later on
converted to MPF. The Satalite RGA is also under MPF.
It should be trivial to convert these to use ASYN drivers for 3.14.x
I will plan on doing this soon.
Will look into the MKS 111 RGA and let you know.
more later
mohan
Mohan Ramanathan                         Critical Component Sys. Mgr.
[email protected]                        Advanced Photon Source
(630)-252-3773 / (630-822-5625 (cell)    Argonne National Laboratory
(630)-252-7187 (FAX)                     Argonne, IL 60439
> Subject: RGA Device Driver
> To: Tech Talk <[email protected]>
> X-MIMEOLE: Produced By Microsoft MimeOLE V6.00.2800.1409
> Importance: Normal
> X-Priority: 3 (Normal)
> X-MSMail-priority: Normal
> X-Spam-Processed: asxl01.synchrotron.vic.gov.au, Mon, 07 Nov 2005 11:03:17
+1100	(not processed: message from valid local sender)
> X-Return-Path: [email protected]
> X-MDaemon-Deliver-To: [email protected]
> Hi all,
>   We have two MKS 111 Spectra Products Residual Gas Analysers in our
> storage ring.
>   At the recent EPICS conference, someone said they had an RGA device
> driver, but I can recall who that was. If you would like to 'fess up
> that would be great, or if anyone else has a driver, any code/examples
> would be appreciated.
> Regards
> Andrew Starritt
> ______________________________________
> Systems Engineer - Software Specialist
> Australian Synchrotron Project
> 800 Blackburn Road, Clayton 3168
> Tel: +61 3 8540 4164
> Fax: +61 3 8540 4200
Prev: RGA Device Driver Andrew Starritt
Next: RE: RGA Device Driver Owens, PH (Peter)
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
