1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: jprobe does not work with jca 2.x
To: "Tech-Talk" <[email protected]>
Date: Fri, 28 Oct 2005 16:40:04 -0500
I have converted Jprobe to JCA 2.1 but it has not been committed.  The
reason is that it is becoming increasingly difficult to maintain Java
packages as extensions in the EPICS build system, especially when they
require more and more extra packages to build.  They are probably best
distributed another way.
Consequently, I have put Jprobe 2.0.0.0 on ftp://ftp.aps.anl.gov/pub/evans
in jprobe.2.0.0.0.zip.  It works with:
JCA 2.1.5
CAJ 1.0.2
And should work with more recent versions, but has not been tested.
You can switch between CAJ and the JCA JNI version by setting
useCAJ=true or false in Jprobe.java.  With CAJ it is Pure Java and
does not need .dll or .so shared libraries.
Note that neither JCA nor CAJ reads the environment for things like
EPICS_CA_ADDR_LIST.  You will need to read the documentation to learn
how to supply them (via properties or the command line) if needed.
You need to get the jar files for JCA and CAJ from Cosylab:
http://jca.cosylab.com/ and http://caj.cosylab.com/
	-Ken
Re: jprobe does not work with jca 2.x Noboru Yamamoto
Prev: Re: jprobe does not work with jca 2.x Thomas Pelaia II
Next: Re: jprobe does not work with jca 2.x Noboru Yamamoto
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
