1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: jprobe does not work with jca 2.x
To: [email protected]
Cc: [email protected]
Date: Fri, 28 Oct 2005 12:40:05 -0700
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
http://www.aps.anl.gov/xfd/SoftDist/swBCDA/jca/index.html says
"Your programs using the old API should still work with JCA2."
That doesn't seem to be the case. The package name has been changed from
jca to gov.aps.jca. Changing the name to gov.aps.jca in the jprobe
source does not fix the problem, because it still references the 1.x
api, e.g., BadCountException, which does not exist in 2.x.
Is there some way to enable compatibility mode or should I use jca 1.x
with jprobe?
Mark Wagner [email protected] 206-598-0302
Unix System Administrator, Radiation Oncology
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.1 (GNU/Linux)
iD8DBQFDYn6VvOs2g/c480IRAg8XAJ9U8cDdnuwq5ITw6jES8Vuuq82EVACgjJZ6
6iXd4XS5hvXMgR/GJycO64c=
=LTOb
-----END PGP SIGNATURE-----
Re: jprobe does not work with jca 2.x Thomas Pelaia II
Prev: EDM wants to build on vxWorks-68040 target. Why? Mark Wagner
Next: Re: jprobe does not work with jca 2.x Thomas Pelaia II
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: EDM wants to build on vxWorks-68040 target. Why? Singleton, SJ (Steve)
