1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: mv162 and nfs
To: [email protected]
Date: Wed, 26 Oct 2005 10:19:32 -1000
Geoff Savage wrote:
We have encountered an issue with an mv162lx running vxworks 5.3.1 when writing to a file via nfs. Every 10 seconds everything stops for 5 seconds. It appears that this is related to the network driver. The suggested solution was to set the ethernet connection to half duplex on the switch. Is this the only solution? The best solution?
Hi Geoff,
how big are the files? We found that for small files it is faster to use
rcp than to do NFS writes. However, we also successfully write larger
files to NFS mounted disks from hkbaja40s and hknitro60s - and we
write logs to NFS mounted disks from other architectures as well,
including mv167s.
We didn't have to do anything special with the ethernet connections
that I know of.
Question: when you say "everything stops" do you mean just the file
writing, or does the whole IOC stop?
Aloha,
Maren
mv162 and nfs Geoff Savage
Prev: mv162 and nfs Geoff Savage
Next: Re: mv162 and nfs Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
