1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: UDP to CA_UDP hangs network?
To: Chris Timossi <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Fri, 21 Oct 2005 14:00:50 -0400 (EDT)
On Fri, 21 Oct 2005, Chris Timossi wrote:
> We are seeing a similar failure to the one described. We have not been
> able to correlate the failure with any network activity and we have not
> tried the nmap test. We did examine the mbufs, memory and task list and
> saw nothing unusual. The only symptom was that CA clients lost
> connections and a reboot of the IOC restored the connections. It's an
> intermitant phenomena that occurs on the time scale of a few per months
> and started relatively recently.
Chris--
The best indicator for the scenario I described is a non-zero value which
does not decrease in the Recv-Q column from inetstatShow() for the beacon
port (typically UDP 1028 +/-2):
-> inetstatShow
Active Internet connections (including servers)
PCB      Proto Recv-Q Send-Q  Local Address      Foreign Address (state)
727480   UDP     1694      0  0.0.0.0.1028          0.0.0.0.0
Adding a shutdown(sock,0) in rsrv_online_notify_task() is working for me.
Steve Hartman
[email protected] || 919-660-2650
Duke Free Electron Laser Laboratory
UDP to CA_UDP hangs network? Steven Hartman
Re: UDP to CA_UDP hangs network? Chris Timossi
Prev: Re: UDP to CA_UDP hangs network? Chris Timossi
Next: Re: autosave V4.1 and caRepeater Tim Mooney
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Capfast symbol for R3.13 scan record Peregrine McGehee
