Hi:
I am compiling the example device support and application
given in “How to create EPICS device support for a simple serial or GPIB
device” guide. I find the guide very useful. The device support part
compiles without any problem. When I compile the application and run the IOC
application I get the following error.
Any one has a suggestion. I have copied the directory
structure and the error messages. I am compiling the programs on a linux
machine using EPICS3.14.7
AB302App AB302Sup
bin configure db dbd documentation iocBoot
lib Makefile
#!../../bin/linux-x86/AB302
## You may have to change AB302 to something else
## everywhere it appears in this file
< envPaths
Can't open envPaths: No such file or directory
macLib: macro TOP is undefined (expanding string cd ${TOP})
dbLoadDatabase("dbd/AB302.dbd",0,0)
filename="../dbLexRoutines.c" line number=234
No such file or directory dbRead opening file
dbd/AB302.dbdAB302_registerRecordDeviceDriver(pdbbase)
registerRecordDeviceDriver failed ai
registerRecordDeviceDriver failed ao
registerRecordDeviceDriver failed bi
registerRecordDeviceDriver failed bo
registerRecordDeviceDriver failed calc
registerRecordDeviceDriver failed calcout
registerRecordDeviceDriver failed compress
registerRecordDeviceDriver failed dfanout
registerRecordDeviceDriver failed event
registerRecordDeviceDriver failed fanout
registerRecordDeviceDriver failed longin
registerRecordDeviceDriver failed longout
registerRecordDeviceDriver failed mbbi
registerRecordDeviceDriver failed mbbiDirect
registerRecordDeviceDriver failed mbbo
registerRecordDeviceDriver failed mbboDirect
registerRecordDeviceDriver failed permissive
registerRecordDeviceDriver failed sel
registerRecordDeviceDriver failed seq
registerRecordDeviceDriver failed state
registerRecordDeviceDriver failed stringin
registerRecordDeviceDriver failed stringout
registerRecordDeviceDriver failed sub
registerRecordDeviceDriver failed subArray
registerRecordDeviceDriver failed waveform
registerRecordDeviceDriver failed asyn
macLib: macro AB302 is undefined (expanding string cd ${AB302})
dbLoadRecords("db/devAB302.db","P=AB302:,R=,L=0,A=0")
No such file or directory dbRead opening file db/devAB302.db## Load
record instances
#dbLoadRecords("db/xxx.db","user=karunacHost")
${TOP}/iocBoot/${IOC})
macLib: macro IOC is undefined (expanding string cd
drvAsynSerialPortConfigure("L0","/dev/ttyS0",0,0,0)
asynSetOption("L0", -1, "baud", "9600")
2005/10/19 16:15:38.409 /dev/ttyS0 Can't open Permission denied
166967288 autoConnect could not connect
bash-3.00$ ls
Makefile st.cmd
Chithra.
Chithra Karunakaran
Canadian Light Source Inc.
Phone: (306) 657-3749
