1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: White Box 4 and medm scalable fonts
To: "Craig Walther" <[email protected]>, "TECHTALK" <[email protected]>
Date: Wed, 19 Oct 2005 13:38:10 -0500
Craig,
I was having a similar problem with RHEL4 a couple of months ago. It
seems that MEDM needs to have the following in the X font server path
for RHEL4 /usr/X11R6/lib/X11/fonts/75dpi.
If you run the command /usr/sbin/chkfontpath you will see a listing of
directories in the font path. By default RHEL4 includes
/usr/X11R6/lib/X11/fonts/75dpi:unscaled which will prevent you from
adding the other font directory to the path. The only way I found around
this was to remove the 75dpi font directories from the path and then add
it back:
	chkfontpath -r /usr/X11R6/lib/X11/fonts/75dpi
	chkfontpath -a /usr/X11R6/lib/X11/fonts/75dpi
This will add both /usr/X11R6/lib/X11/fonts/75dpi and
/usr/X11R6/lib/X11/fonts/75dpi:unscaled to you font path.
Conrad G. Zadlo, Jr.
Computer Network Assistant
Intense Pulsed Neutron Source (IPNS)
9700 S. Cass Av. Bldg 360
Argonne, IL 60439
[email protected]
Phone: 630-252-3207
Fax: 630-252-9987
-----Original Message-----
Sent: Tuesday, October 18, 2005 4:08 PM
To: TECHTALK
Subject: White Box 4 and medm scalable fonts
Hi Folks:
Has anyone had problems with medm scalable fonts with White Box
Enerprise Linux 4 (WBEL4).  We just installed this on our machines and
cannot get the medm scalable fonts to work.  They did work with WBEL3.
Craig
Craig Walther              Email: [email protected]
Joint Astronomy Centre     Phone: (808) 969-6556
660 N. A'ohoku Place       Fax:   (808) 961-6516
Hilo, Hawaii  96720 USA
Prev: EPICS/Labview shared memory implementation and Labview 8 Chestnut, Ronald P.
Next: More on fonts and RHEL4 Chestnut, Ronald P.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: White Box 4 and medm scalable fonts Craig Walther
Next: EPICS/Labview shared memory implementation and Labview 8 Chestnut, Ronald P.
