1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: 64-bit EPICS anyone?
To: "Ernest L. Williams Jr." <[email protected]>
Cc: [email protected], EPICS tech-talk <[email protected]>
Date: Mon, 17 Oct 2005 17:28:38 -0400 (EDT)
On Sat, 15 Oct 2005, Ernest L. Williams Jr. wrote:
> So EPICS BASE is really running in 64-bit mode, wow that was easy.
> I hope something is not broken at run time.
I played with epics base on 64-bit sparc (Solaris) a number of years ago
(but never bothered to put it into widespread use).  As far as I could
tell, everything with base was fine. I do not know about various
extensions, though.
The big caveat is to avoid mixing 32- and 64-bit libraries/applications.
Your approach of a separate HOST_ARCH (and hence installation directories)
with linux-x86_64 is likely necessary.  Depending upon how various
distributions have configured gcc defaults, it may also be desirable to
explicitly set the compiler flags (-m32 for linux-x86 and -m64 for
linux-x86_64) so you don't inadvertently get a mix within an install
directory depending upon the build host.
Steve Hartman
[email protected] || 919-660-2650
Duke Free Electron Laser Laboratory
Re: 64-bit EPICS anyone? Ernest L. Williams Jr.
Re: 64-bit EPICS anyone? Zhijian Yin (ZY)
Prev: RE: UDP to CA_UDP hangs network? Steven Hartman
Next: Re: 64-bit EPICS anyone? Ernest L. Williams Jr.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: 64-bit EPICS anyone? Ernest L. Williams Jr.
