1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: IP Carrier Board - Linux Drivers for Hytec IP Cards
To: "'Luchini, Kristi'" <[email protected]>
Cc: <[email protected]>
Date: Wed, 12 Oct 2005 11:55:57 +0100
Hello,
I am at this very moment enhancing Martin Kraimer's Linux Driver for the
SBS PCI-40B Carrier to support the Hytec range of IP Cards (ADCs, DACs,
Digital I/O, RS232, RS422, RS485, Stepper Motors etc).  It would very
little effort to convert to any other SBS IP Carrier cards.  Is there
any particular functionality / IP card you were after supporting, that
we could make it a priority.
Darrell Nineham
Hytec Electronics Ltd.
Tel: +44 (0) 118 975 7770
Fax: +44 (0) 118 975 7566
Web: www.hytec-electronics.co.uk
This email and any files transmitted with it are confidential and
intended solely for the use of the individual or entity to whom they are
addressed. If you have received this email in error, please notify the
sender immediately. The views expressed in the message are those of the
individual author and may not necessarily represent the views of Hytec
Electronics Ltd.
-----Original Message-----
Sent: 11 October 2005 15:49
To: [email protected]
Hello,
Has anyone written drivers for some of the newer VME (not 64X) IP
Carrier boards. It seems that there are at least one driver that Andrew
recently wrote for the Tews TVME200 (aka VIPC626), so that board is an
option. And using Andrews ip carrier generic software package writing
the software for newer carrier boards should be relatively easy but if
the work is already done, that's even easier and it would be great to
take advantage of that work if possible. So if there are any drivers
available or ip carrier boards that people can recommend please let me
know. I've used SBC ip carriers before and they have been quite
reliable, so that's the direction I'm leaning towards right nowunless
someone has had good experience with other ip carrier board. Thanks for
you help.
Some of the ip carriers we're looking at (but are not limited to) are:
 1) SBS VIPC627
 http://www.sbs.com/products/741/
 2) SBS VIPC8244
http://www.slac.stanford.edu/grp/lcls/controls/global/subsystems/magnet/
slaconly/SBS_datasheet_VIPC8244_DS.pdf
 3) SBS VIPC8243
slaconly/SBS_datasheet_VIPC8243_DS.pdf
 4) Xycom TVME200 (driver same as VIPC626)
http://www.xycomvme.com/folder.2004-06-24.1215397535/folder.2004-06-24.1
723358754/tvme200_10.html/view?searchterm=TVME200
 5) SBS VIPC626-ET (Andrew Driver avail) http://www.sbs.com/products/480
  Kristi
IP Carrier Board Luchini, Kristi
Prev: RE: Asyn build under win32 Mark Bennett
Next: RE: Asyn build under win32 Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: IP Carrier Board Luchini, Kristi
Next: Accessing ControlLogix PLC program tags with EtherIP Mike Forster
