1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Channel Access Gateway (Problems at the SLS)
To: "Dalesio, Leo `Bob`" <[email protected]>
Cc: <[email protected]>
Date: Mon, 10 Oct 2005 16:58:54 +0100
We are running a test gateway at Diamond and have experienced problems
when doing large transfers (EPICS_CA_MAX_ARRAY_BYTES=3000000). I have
posted to techtalk on previous occasions regarding the problem. Ken
Evans kindly responded drawing my attention to Mantis bug #176 however
we are running an EPICS cvs snapshot that post dates this fix. Clearly
running with a cvs snapshot is not ideal and may in itself be a problem.
Currently I am hoping that EPICS 3.14.8 appears very soon so that I can
try it with the new Gateway release. Since we already have the #176 fix
I am not sure this will solve our problems but I am hopeful.
Pete Leicester
Diamond Light Source
-----Original Message-----
Sent: 10 October 2005 14:25
To: Dalesio, Leo `Bob`
Cc: [email protected]
Subject: Re: Channel Access Gateway (Problems at the SLS)
I have been administering the PV gateways (40 of them) at the APS since
the beginning of the PV gateway. There have been issues along the way,
however, at this time I feel that for at least the past year the PV
gateways at APS have been performing rather well.
There are currently no problems that I have seen that can be attributed
directly to the current PV gateway (version 2). I have encountered
problems in the past, but there has been nothing to prove to me that
they were being caused by the PV gateway.
Marty Smith
Dalesio, Leo `Bob` wrote:
> Hi All,
> A change of title would be a bit more precise (as well as sensative).
> Airing issues is what a collaboration meeting does best when things
> are going well. It is a chance to explain what is going wrong for
> others. It would have been nice to see if anyone else is experiencing
> any of the reported problems. Is anyone?
> Some of the things reported in this talk as bugs are simply the way
> that the gateway must work to actually limit traffic. For instance, if
> you connect to the same channel 5 times, one is periodic and the other
> is moniitor - the monitor is considered to be the most up to date
> value. If a large MDEL makes the value less useful for the application
> that wants to do a get - use a smaller MDEL to the gateway. It is fine
> to point out how a particular tool works in ways that were not
> expected by the user. It gives others a heads up.
> It would be nice to go beyond the imperfect way we communicate and
> have a list of the issues posted and a response to whether or not the
> situation is the intentional implementation of the gateway and some
> pointers on how to get the tool to provide what you want, if the
> situation is a site specific problem that cannot be reproduced and
> perhaps some pointers fromt the community on a way to get more
> diagnostic information to further characterize the problem, and
> finally isolate anything that is a problem with the gateway so that
> people with very limited time that have provided very valuable support
> to the community can provide some help.
> We have precedent for having these people come to your site and help
> you to diagnose the issue. This is normally done at the expense of the
> site requesting support. Even though it may be a problem in the code
> authored elsewhere, it is really important to remember that these are
> very large codes, supported almost entirely at the expense of some
> other project.
> Bob
Prev: Re: Channel Access Gateway (Problems at the SLS) Martin L. Smith
Next: Qt-compatible Channel Access lib Mark Davis
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
