1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: modbus over tcp/ip
To: Paul Sichta <[email protected]>
Cc: "Peng, Sheng" <[email protected]>, [email protected]
Date: Mon, 10 Oct 2005 08:36:30 -0400
Paul,
I looked at the available modbus code a few months ago and found it supported only a small subset of modbus codes. It seems it was developed for talking to a particular PLC, via register reads and writes, rather than a more general modbus device. If your goal is similar you may be happy with the CLS/BNLS code. If your goal is to be able to support a variety of modbus devices you'll need to do some additional device/driver development.
Sheng,
I am also interested in learning about the modbus device support at SNS.
John Dobbins
Research Support Specialist
Laboratory for Elementary Particle Physics
Cornell University
Paul Sichta wrote:
Sheng,
I visited SNS a few weeks ago and Ernest showed me the Beckhoff hardware which he said you wrote a modbus driver/device support for. Was that working well? I am thinking of trying out the Beckhoff stuff.
I will be supporting some modbus tcp/ip devices in the near future and have the CLS and some upgraded (APS?) source but haven't looked at it yet. What limitation did that have for you, so that you needed to write a new version?
modbus over tcp/ip Geoff Savage
FW: modbus over tcp/ip Peng, Sheng
Re: modbus over tcp/ip Paul Sichta
Prev: Re: modbus over tcp/ip Paul Sichta
Next: Channel Access Gateway (Problems at the SLS) Dalesio, Leo `Bob`
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Spam on tech-talk J. Frederick Bartlett
