1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Channel Access Gateway Bugs
To: EPICS tech-talk <[email protected]>
Date: Sat, 08 Oct 2005 18:30:53 +0200
Dear all,
Ken's mail is showing to me clearly that we are all not only technical people but also human beings with personal feelings - which have been tempted (if this is the right term) in this case.
I am sure that those mentioned by Ken are about to reply directly - so should I.
But I think we should at first think it over and see what went wrong. There are always more than one party involved if such a mail gets written.
I want to propose that first of all Ken and Dirk get in contact directly (leaving out cc-mail to tech-talk) and present their technical findings afterwards - here.
Second I want to invite Ken to a glass of wine to understand what went wrong.
Last not least I was glad to see many of you in Archamps.
And - by the way - the presentations - yes all of them - are already on the web.
Maybe there's a chance to add one or two pages with recent results/ solutions to one of the presentations?
Regards
Matthias
[email protected] wrote:
This note is in reponse to the talk presented at the EPICS Collaboration Meeting yesterday at Archamps and entitled "Channel Access Gateway Bugs".
This talk broadsided me. I was not aware that it was to be given, since neither the author nor my colleagues informed me; there was no printed aganda available; and I had no particular reason nor convenient means of viewing the program online. To say that it ruined an otherwise pleasant meeting for me is an understatement.
I am very conscientious and concerned about my programs working well, and I spend much of my life insuring that they do and also in helping people with problems with EPICS software of all kinds. The same may be said of most of the people with whom I work. I think a paper on the [alleged] bugs in someone else's program is an inappropriate subject for a presentation at a meeting where the proceedings are made available to the entire world.
That, in addition, one of the conference organizers stated that this was the best paper of the meeting is completely inappropriate, in my opinion. If this collaboration feels this type of paper is the best sort, then it is a collaboration of which I do not wish to be a part.
I do not object to criticism, rather I feel strongly that it needs to be done professionally, in an atmosphere of respect and consideration, the same atmosphere in which people should be treated in general.
To respond to the presentation itself: The automobile is one of the most useful inventions of our time. However, when misused it kills people, more even than the wars we wage. The same can be said of the Gateway, though it is neither as valuable nor as destructive. Thus, I will respond to the conclusion of the paper first and agree wholeheartedly that Gateway, as with any other software that is critical to your control system, must be used with caution until you are sure it will not have an adverse impact. It is clear that the Gateway is not working that way for Dirk.
On the other hand it works very well under heavy and extensive use on both Linux and Solaris at the APS, the only situation over which I have any control. This experience is described in a paper available on the Gateway web page, along with the manual and other relevant information. Apart from Dirk's problems and known problems with the Alarm Handler, which were stated in this forum recently, I am not aware that other sites are having any problems that have not been fixed by using 3.14.7 plus the latest patches from Jeff. It would not hurt, but is not as critical, to use the latest version of the Gateway. Otherwise I would not have released it this week. The point is that many sites are using the Gateway successfully and not finding the "bugs" that Dirk does.
The fact is that the Gateway is arguably the most powerful Channel Access application and the one that stresses Channel Access the most. In our case it is serving all of the process variables from several hundred IOCs, requiring that it contact those IOCs as a Channel Access client, such as MEDM, and also act as a server, such as an IOC, to the huge numbers of MEDMs and other clients that are attached to it. It is typically used in an extended network environment spanning several subnets. To manage the Gateway properly requires significantly more knowledge, especially in the areas of networking in general and in the internal operation of Channel Access, than running a program such as MEDM does. It is for this reason that much of this informaion is included in the Gateway Reference Manual and in other presentations I have made and which are available on the Gateway web site. It is up to the Gateway administrator to understand it.
Dirk states that the Gateway does not forward beacon anomalies correctly. The fact is that it does not forward them at all. It does generate a beacon anomaly when it starts, as do all CA servers, and it also generates a beacon anomaly when any IOC to which it has been connected reconnects after being disconnected. Whether these are forwarded depends on the network. Beacon anomalies are UDP broadcasts, and many routers do not propagate UDP broadcasts across subnets for security reasons. In any event, it is easy to tell. You just run CASW (as described in the manual and in many other links from the Gateway web page). Similarly, you run CaSnooper to see if search requests from clients connected to the Gateway are happening as expected. It was not stated if Dirk has done that or not, but it should be done before presenting papers such as this.
The problem Dirk mentions that if any client connects a monitor, then all clients only get the latest monitor value is hard for me to understand. What the Gateway does is monitor the value itself from the IOC. It caches this value whenever it receives it and then post monitors to any MEDMs attached to it that have requested monitors and also gives this value to any clients that do gets. There is only one value in the Gateway, and it is the most current it has received. This is not a bug, this is what it does. If it does not have the latest value from the IOC, there is more likely a problem with the IOC or the network, not the Gateway, and those need to be investigated. The same could be said of MEDM or any other clients. The client side of the Gateway is no different than the client side of MEDM.
In regard to large arrays: We have been running our whole control system with EPICS_MAX_ARRAY_BYTES set for more than a year. There was a bug in Channel Access related to doing that that was tracked down by me and fixed by Jeff some time ago. Other than that, there have been no problems, and there are no problems now that I am aware of. Nobody is complaining, here. In addition, you do need to set it large enough to hold the maximum number of bytes being sent plus some extra for the protocol header. However, if you request more bytes than that, you should just get a message saying it won't be allowed. It does not crash the Gateway nor the clients for us.
In any event, I cannot duplicate Dirk's problems, and our more than 50 Gateways work quite well. To proceed further he needs to do some investigating himself. A site the size of PSI should have someone with the ability to get the Gateway in a debugger and determine what, if anything it is doing wrong. That is what I would do if I were there. I cannot fix his problem with the information given, and I cannot be there to do it myself. The benefits of the collaboration is that it did not cost him anything. The disadvantage is that he may have to do some of the work himself.
Matthias Clausen                         Cryogenic Controls Group(MKS-2)
phone:  +49-40-8998-3256                Deutsches Elektronen Synchrotron
fax:    +49-40-8994-3256                                    Notkestr. 85
e-mail: [email protected]                           22607 Hamburg
WWW-MKS2.desy.de                                                 Germany
Channel Access Gateway Bugs evans
Prev: Channel Access Gateway Bugs evans
Next: FW: modbus over tcp/ip Peng, Sheng
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: Channel Access Gateway Bugs Dirk Zimoch
