Jeff,
I just learned a little more about the caRepeater problem. When I did the tests in my previous message I had not run any Windows CA clients that would have started a Windows caRepeater task. When I started the IOC it started a caRepeater task that appears with "ps -a" in cygwin, but did not appear in the Windows Task Manager. I got the error saying that CA could not find the caRepeater. The copy of caRepeater that was started under cygwin had the unfortunate property that it had a file open that my IOC application had opened, and that file could not be deleted until that copy of caRepeater was killed.
I then started medm on the Windows machine, which created a caRepeater task that shows up in the Windows Task Manager. That time starting the IOC did not start a caRepeater task, since it must have found the one that was running under Windows. However, I still got the following error at the IOC:
epics> CA client library is unable to contact CA repeater a
Silence this message by starting a CA repeater daemon
or by calling ca_pend_event() and or ca_poll() more often.
But at least this copy of caRepeater does not have the file locked that needs to be deleted!
Do you understand what is going on?
Sent: Fri 9/30/2005 3:33 PM
To: Jeff Hill; [email protected]
Subject: RE: Channel access problem on cygwin IOC
Jeff,
The think the problem might have been caused by EPICS launching a second copy of my IOC instead of caRepeater one time. So there were two copies of the IOC application running, causing the IP problem?
There is something else I don't understand about caRepeater behavior on this IOC.
Here is a list of cygwin processes before I start my IOC.
$ ps -a
PID PPID PGID WINPID TTY UID STIME COMMAND
1364 1 1364 1364 ? 18 20:29:52 /usr/bin/cygrunsrv
1660 1364 1660 1672 ? 18 20:29:57 /usr/sbin/sshd
I 460 1 460 460 0 11092 20:31:24 /usr/bin/bash
2280 1 2280 2280 1 11092 14:02:41 /usr/bin/bash
3808 2280 3808 2740 1 11092 14:03:38 /usr/bin/ps
Now I start the IOC. Note that the path to caRepeater in EPICS base is in my cygwin PATH. Now list the processes again.
$ ps -a
I 2112 460 2112 3008 0 11092 14:03:49 /cygdrive/j/epics/devel/dxp/2-4beta/bin/cygwin-x86/xmapApp
736 2112 2112 3284 0 11092 14:04:49 /cygdrive/h/epics/base/bin/cygwin-x86/caRepeater
3932 2280 3932 3456 1 11092 15:14:12 /usr/bin/ps
xmapApp is the IOC process. Note that starting the IOC has started the caRepeater, as it should have.
However, I get the following message from iocsh on the IOC after iocInit is complete.
CA client library is unable to contact CA repeater after 50
This does not seem right. Why am I getting that error message even though caRepeater was in fact successfully started?
- RE: Channel access problem on cygwin IOC Jeff Hill
Re: Possible improvements to simulation mode [patch] Ned Arnold
<2005>
RE: Channel access problem on cygwin IOC Mark Rivers
<2005>
