Ned and Larry,
Thank YOU that you return me on right way :) Ernest explained me
"level" yesterday. But I like to read myself.
There is "ASL: Access Security Level (Called access level in Req
Doc" and I decided Req is Record. As you know I tried to search in
Record's manual and looked into /src but information was closer ...
Also additional information about "ASL1=the default" to help me
understand *Record.dbd
Have a good day, Andrei.
-----Original Message-----
Sent: Friday, September 30, 2005 9:10 AM
To: Liyu, Andrei
Cc: [email protected]
Subject: Re: ASL field
Andrei,
The ASL is *not* a field in the record. It is an attribute defined for
each field in a record type in the xxxRecord.dbd file. For example
field(VAL,DBF_ENUM) {
prompt("Current Value")
promptgroup(GUI_INPUTS)
pp(TRUE)
asl(ASL0)
Fields that are routinely changed by operators get assigned ASL0, more
sensitive fields get assigned ASL1 (the default).
To change the ASL level of a field will require a new record type, i.e.
Andrei'sAIrecord
Andrei'sBIrecord
I have been in enough conversations about this to know that everyone has
there own opinion as to the effectiveness of this approach, so you won't
be saying anything new, Andrei.
Ned
Liyu, Andrei wrote:
> Hi,
> I am working with Channel Access Security and read manuals again :(
> Maybe I am mistaken but I couldn't find enough information about ASL
> field.
> Channel Access Security is based on ASG and ASL record's fields. So
> Application Developer's Guide; 8.3.3 Definitions "... ASG ... ASL ..."
> 1. But Records Reference manual hasn't any information about ASL.
> 2. Also link between ASL and <level> in Application Developer's Guide;
> 8.3.4.2 and 8.3.4.3 is not clear.
> Of course, struct dbFldDes in dbBase.h has
> asLevel as_level; /*access security level
Re: ASL field Ned Arnold
RE: Asyn build under win32 Jeff Hill
<2005>
Possible improvements to simulation mode [patch] Denison, PN (Peter)
<2005>
