The ASL is *not* a field in the record. It is an attribute defined for each field in a record type in the xxxRecord.dbd file. For example field(VAL,DBF_ENUM) { prompt("Current Value") promptgroup(GUI_INPUTS) pp(TRUE) asl(ASL0) } Fields that are routinely changed by operators get assigned ASL0, more sensitive fields get assigned ASL1 (the default). To change the ASL level of a field will require a new record type, i.e. Andrei'sAIrecord Andrei'sBIrecord I have been in enough conversations about this to know that everyone has there own opinion as to the effectiveness of this approach, so you won't be saying anything new, Andrei. Ned Liyu, Andrei wrote: Hi,
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
