1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: VxWorks5.5 on MVME230x doesn't reestablish broken N/W link
To: Andreas Isenegger <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Wed, 28 Sep 2005 18:55:30 -0400
On Wed, 2005-09-28 at 17:12 +0200, Andreas Isenegger wrote:
> Hello All,
> Since I posted 2 e-mails in July 2005 seeking for help, I thought it would
> be worth informing you that the problem could be solved.
> There are indeed some bugs in Wind River's N/W driver (dec21x40End.h/c) that
> cause the misbehavior of the IOC. I got new revisions of these files from
> Martin Niedermair, WRS Austria, which solve the issue. Strangely enough, a
> different support engineer of WRS sent me another revision of the same
> files, which doesn't fix the bug. About 2 years back, they were branched...
> . The latest official patch from WRS contains again different revisions of
> the files.
> Thus, if you are experiencing troubles with IOC's disconnecting for 'no
> reasons', or reset ports of N/W switches to regain links to IOC's, build a
> new VxWorks image with the latest revision of these files.
Can you send us a copy of the files or give us a rev. number to compare
against?
I think we are fine but I want to double-check.
Our MVME2101s also use the "dec21x40End.h/c"
PS: Did WRS give you a TSR or SPR that we could look up on our end?
Ernest L. Williams Jr.
SNS Control Systems Group
ORNL
> Kind regards,
> Andreas Isenegger
> Andreas Isenegger
> SLS Controls
> Paul Scherrer Institute, WSLA/207
> CH-5232 Villigen PSI, Switzerland
> Tel/Fax: ++41 (56) 310 5125/4413
Re: VxWorks5.5 on MVME230x doesn't reestablish broken N/W link Andreas Isenegger
Prev: Re: VxWorks TIMEZONE hack, anyone? Steven Hartman
Next: Re: VxWorks5.5 on MVME230x doesn't reestablish broken N/W link Andreas Isenegger
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: VxWorks5.5 on MVME230x doesn't reestablish broken N/W link Andreas Isenegger
