1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: striptool strangeness
To: "Laznovsky, Michael" <[email protected]>
Cc: TECHTALK <[email protected]>
Date: Mon, 26 Sep 2005 09:47:18 +0200
That happens when the data range (here: 4.7e4) is much larger than the axis range (here: 100). This seems to be a bug in the Striptool display routine. I have seen this effect often.
Dirk
Laznovsky, Michael wrote:
Hi all-
For a while now I've noticed an odd effect in one of my ongoing striptool
charts... one of the PVs I follow starts at zero when an IOC is booted and just counts up from there, one step every 3.7 seconds or so, as you can see on this full-scale chart ("LM20:DATA:COUNT", the diagonal maroon line):
http://www-user.slac.stanford.edu/lazmo/tmp/lm20-stripbug2.gif
But when striptool is set to user-specified axis limits, that PV mysteriously
keeps regularly reappearing in the interval (0,100) as though it had been
reset to zero:
http://www-user.slac.stanford.edu/lazmo/tmp/lm20-stripbug.gif
The phantom period looks to be about 5.5 hours, which translates to about
19800 seconds, or 5300 counts of the PV; apparently not an obvious power-of-2 wrap-around effect in this case.
Haven't seen any other PVs do this, but then I don't follow any other
monotonically-increasing ones.  No big deal, unless it reveals some underlying
bug that may be subtly affecting other displays.
Any ideas??
thanks, Mike
Michael P. Laznovsky                         mailto:[email protected]
Application Software Developer, ESD                     ofc: (650) 926-2924
Stanford Linear Accelerator Center, MS-46               fax: (650) 926-3515
2575 Sand Hill Road, Menlo Park CA 94025 USA   http://www.slac.stanford.edu
-- Dr. Dirk Zimoch Swiss Light Source Paul Scherrer Institut Computing and Controls phone +41 56 310 5182 fax +41 56 310 4413
striptool strangeness Laznovsky, Michael
Prev: Re: Failure probing for event generator Ernest L. Williams Jr.
Next: VxWorks5.5 on MVME230x doesn't reestablish broken N/W link Andreas Isenegger
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: striptool strangeness Laznovsky, Michael
Next: scan task stack overflow Geoff Savage
