1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: scan task stack overflow
To: Geoff Savage <[email protected]>
Cc: [email protected]
Date: Thu, 22 Sep 2005 07:31:18 -0500
Geoff Savage wrote:
We have overflowed the stack of the scan5 task by putting too many records at a 5 second scan rate. What is the best way to handle this situation? Aside from reducing the number of records.
Thanks, Geoff
The other reply's all give good advice so I just want to add a couple of comments
The number of records in a particular scan set will NOT cause a stack overflow. Thus
What can cause a stack overflow is too many records linked together via forward links or process passive database links. A linked record is processed by a recursive call to dbProcess. Each call uses additional stack space.
Another thing that cause stack overflow is support routines allocating lots of stack space. For example
void badSupport( ...)
     double data[1000];
The above allocates 8000 bytes of stack space.
Marty Kraimer
scan task stack overflow Geoff Savage
Prev: Re: scan task stack overflow Ralph Lange
Next: EDM <--> MEDM display-file translators Tim Mooney
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: scan task stack overflow Geoff Savage
Next: RE: scan task stack overflow Laznovsky, Michael
