1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: striptool strangeness
To: "TECHTALK" <[email protected]>
Cc: "Laznovsky, Michael" <[email protected]>
Date: Wed, 21 Sep 2005 18:14:49 -0700
Hi all-
For a while now I've noticed an odd effect in one of my ongoing striptool
charts... one of the PVs I follow starts at zero when an IOC is booted and
just counts up from there, one step every 3.7 seconds or so, as you can see
on this full-scale chart ("LM20:DATA:COUNT", the diagonal maroon line):
http://www-user.slac.stanford.edu/lazmo/tmp/lm20-stripbug2.gif
But when striptool is set to user-specified axis limits, that PV mysteriously
keeps regularly reappearing in the interval (0,100) as though it had been
reset to zero:
http://www-user.slac.stanford.edu/lazmo/tmp/lm20-stripbug.gif
The phantom period looks to be about 5.5 hours, which translates to about
19800 seconds, or 5300 counts of the PV; apparently not an obvious power-of-2
wrap-around effect in this case.
Haven't seen any other PVs do this, but then I don't follow any other
monotonically-increasing ones.  No big deal, unless it reveals some underlying
bug that may be subtly affecting other displays.
Any ideas??
thanks,
Mike
Michael P. Laznovsky                         mailto:[email protected]
Application Software Developer, ESD                     ofc: (650) 926-2924
Stanford Linear Accelerator Center, MS-46               fax: (650) 926-3515
2575 Sand Hill Road, Menlo Park CA 94025 USA   http://www.slac.stanford.edu
Re: striptool strangeness Dirk Zimoch
Prev: Re: Error using Agilent E5810A LAN/GPIB Gateway Benjamin Franksen
Next: scan task stack overflow Geoff Savage
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: striptool strangeness Dirk Zimoch
